Tell me more ×
Is there a short tutorial describing simple, low voltage circuit switching using the LPT port?
I know it could be done using USB or RS 232 relays, but I would like to assemble it with (buying) minimum or none electronic components, except things I have: an LPT cable, a LED diode or a fan, and a 12 V adapter.
Thank you.
share|improve this question
"a LED diode or a fan" How can you have one or the other? Is this a student project, perchance? – HikeOnPast Oct 29 '12 at 20:35
Yes it is, although I'm not a student, or is this homework or test. – JJ_Jason Oct 29 '12 at 20:37
Where do you even find a computer with a parallel port these days? – Theran Oct 30 '12 at 16:57
Now that's a constructive comment.. – JJ_Jason Oct 30 '12 at 17:54
1 Answer
This is one way:
Parallel Port Controlled LEDs
share|improve this answer
by copying inpout32.dll you'll opening your door to many bad things. – sandun dhammika Oct 29 '12 at 20:52
Would you mind elaborating? – JJ_Jason Oct 29 '12 at 20:56
Source code for that DLL is freely available. You can check it and compile yourself, if you are concerned with safety. – Al Kepp Jan 27 at 23:28
discard
