Tell me more ×
Pardon me, I'm a total newb to electronics. My question is, when a device is measured in watts, such as a 60-watt light bulb, is this ALWAYS supposed to be assumed to be watt-hours, i.e. 60 watts per hour?
share|improve this question
up vote 29 down vote accepted
Energy is an amount, while power is a rate at which energy is used.
  • Energy is measured in watt-hours (W·h) or joules (J).
  • Power is measured in watts (W) or joules per second (J/s).
Watt-hours are like buckets, and watts are like buckets per hour. If you have 5 buckets of energy and you pour one bucket per hour, you'll be able to pour for 5 hours before you run out.
If you turn on a 60-watt light bulb for 1 hour, you have used 60 watt-hours of energy. If you use it for 2 hours, you have used 120 watt-hours of energy. If you turn it on for only 1 minute, you have used 1 watt-hour.
It's a little confusing since the "per hour" is inside the term "watt", so to make the rate into an amount, you need to multiply by a time unit to cancel it out.
It would be a lot more intuitive if we worked in kilojoules and kilojoules per hour. :)
share|improve this answer
+1. The media gets this wrong all the time. – Jason S Sep 30 '10 at 12:24
The media is a great place to learn how to do things correctly ;-) – Kellenjb Sep 30 '10 at 12:36
When the media does a report on something like terahertz, it kills me inside. – Kortuk Sep 30 '10 at 14:47
You mean terahertz imaging in airports? – endolith Sep 30 '10 at 15:41
In fact, in most engineering and science, we DO use kilojoules instead of watt-hours. Especially since watts and joules are SI units and hours are not. (Hours are in the "units outside the SI that are accepted for use with the SI" category.) – wjl Aug 2 '11 at 17:19
show 1 more comment
One point not yet mentioned: a 60 watt bulb will use 60 watt-hours per hour, or 60 watt-seconds per second, or 60 watt-microseconds per microsecond, or 60 watt-centuries per century. In other words, the "watts" part of the bulb's power usage has nothing to do with hours or any other unit of time.
+1 for decoupling watts and hours. (However watts do have a reference time unit as part of their definition: W = J/s.) – wjl Aug 2 '11 at 17:15
@wjl: Remember, though, a joule is the amount of energy required to move an object against a static force of one newton, by the distance that light would travel in 1/299,792,458 second. Consequently, a watt is the amount of power required to push an object against a static force of one newton, at a constant velocity of 1/299,792,458 the vacuum speed of light. No time reference required. – supercat Aug 2 '11 at 17:49
Stimpy, the power rating tells you the rate at which the device consumes energy. So yes, a 60-Watt bulb will consume 60W*h or 0.06kWh of electricity in one hour. Watt-hours measure energy consumption. There is a simple little page here that shows some calculations.
I would also strongly recommend reading the HyperPhysics box on Work, Energy, and Power, and especially the links on the Power Concepts page.
Thanks, "Pingswept". Also, what is different about our two answers? Is this just a case of the topmost effect? – Mark C Oct 5 '10 at 6:15
You are correct in assuming a 60 watt device will consume 60 watt-hours in one hour, but the former (power) is a rate, the latter is an amount (energy).
You mean that it will consume 60 watt-hours in one hour – Ian Sep 30 '10 at 10:16
The concept of 'Watt-hours' as Watt x Hours will be confusing to someone who cannot conceptualize Watt - being 'enegergy used per amount of time'.
I sometimes try to explain this using more familiar concepts: If we use the term 'Keem' in stead of 'km/hour', one could use 'Keem-Hour' to describe distance travelled - going 60 Keem for half an hour means you've travelled 30km as 60 x 0.5=30
Just like a rental company that's interested in the distance your travelled in their car, the energy company is interested in the energy used - they will charge you per Watt-hour. If a Watt-hour costs 1c, it will cost you 60c if you leave a 60 Watt lamp on for one hour.
discard
