I have LS20031 GPS module (I believe with MT3339 chip) connected to Arduino. Using SoftwareSerial reading data when available(). 57600 is the baudrate for GPS. However, I rarely get checksum at all. Here is sample output.
$GPGGA,211152.400,4011.3996,N,04431.9971,E,1,3,5.75,135.5,M,14.37,,$GPGGA,211152.600,4011.3996,N,04431.9970,E,1,3,5.75,135.5,M,14.$67
2$GPGGA,211152.800,4011.3996,N,04431.9969,E,1,3,5.75,135.5,M,14.9802$GPGGA,211153.000,4011.3996,N,04431.9968,E,1,3,5.75,135.5,M,14.9000N$GPGGA,211153.200,4011.3997,N,04431.9967,E,1,3,5.75,135.5,M,14.,70M$GPGGA,211153.400,4011.3997,N,04431.9965,E,1,3,5.75,135.5,M,14.41,$GPGGA,211153.600,4011.3997,N,04431.9964,E,1,3,5.75,135.5,M,14.9602N$GPGGA,211153.800,4011.3998,N,04431.9963,E,1,3,5.75,135.5,M,14.950$,$GPGGA,211154.000,4011.3999,N,04431.9962,E,1,3,5.75,135.5,M,14.40.K$GPGGA,211154.200,4011.3999,N,04431.9961,E,1,3,5.75,135.5,M,14.L7,8$GPGGA,211154.400,4011.4000,N,04431.9959,E,1,3,5.75,135.5,M,14.4.8,$GPGGA,211154.600,4011.4000,N,04431.9958,E,1,3,5.75,135.5,M,14.960M,$GPGGA,211154.800,4011.4001,N,04431.9957,E,1,3,5.75,135.5,M,14.,,,3$GPGGA,211155.000,4011.4001,N,04431.9956,E,1,3,5.75,135.5,M,14.4784$GPGGA,211155.200,4011.4002,N,04431.9955,E,1,3,5.75,135.5,M,14.4.,$GPGGA,211155.400,4011.4002,N,04431.9955,E,1,3,5.75,135.5,M,14.4,$9$GPGGA,211155.600,4011.4002,N,04431.9954,E,1,3,5.75,135.5,M,14.4,7.$GPGGA,211155.800,4011.4003,N,04431.9953,E,1,3,5.75,135.5,M,14.1$P2$GPGGA,211156.000,4011.4003,N,04431.9953,E,1,3,5.75,135.5,M,14.,007,.$GPGGA,211156.078,4011.4003,N,04431.9953,E,1,3,5.75,135.5,M,14.2.,GAG$GPGGA,211156.400,4011.4004,N,04431.9953,E,1,3,5.75,135.5,M,14.,7,2$GPGGA,211156.600,4011.4005,N,04431.9952,E,1,3,5.75,135.5,M,14.962.K$GPGGA,211156.800,4011.4005,N,04431.9952,E,1,3,5.75,135.5,M,14.9*0N4$GPGGA,211157.000,4011.4005,N,04431.9952,E,1,3,5.75,135.5,M,14.9G22$GPGGA,211157.200,4011.4005,N,04431.9953,E,1,3,5.75,135.5,M,14.P*
2$GPGGA,211157.400,4011.4005,N,04431.9953,E,1,3,5.75,135.5,M,14.G7,.$GPGGA,211157.600,4011.4006,N,04431.9953,E,1,3,5.75,135.5,M,14.9S,N$GPGGA,211157.800,4011.4006,N,04431.9952,E,1,3,5.75,135.5,M,14.,.N$GPGGA,211158.000,4011.4006,N,04431.9952,E,1,3,5.75,135.6,M,14.,7,2$GPGGA,211158.200,4011.4006,N,04431.9952,E,1,3,5.75,135.6,M,14.,.
GPS module is blinking red which means it has enough satellites. Also I can see 3 satellites are found in the messages and fix. This module is brand new and less likely it can be buggy.
I also tried TinyGPS library, particularly examples. There is a strange thing. If I just run the program, it will give me no data and checksum errors slowly increasing.
If I leave the program for a while, it will occasionally produce data (sentence).
I have tried to change RX pin as well as Arduino itself, to exclude error there.
Update:
Here is some data, when I take the module inside of house, so it will be out of satellite coverage:
How to find the where is the problem? What additional information I can provide?
