Microchip's website has a document named Using the right Format, Syntax and Definitions for PICmicro Configuration Bits that explains where to find the configuration settings for your particular device.
For example it states for the PIC16F1 devices with a C Compiler:
C Compiler:
Format: Defined in the User Manual Located at:
C:\Program Files\HI‐TECH Software\PICC\\docs\
Definition/Syntax: Located in respective product's header file. Use
the pic16f1xxx.h header file at:
C:\Program Files\HI‐TECH Software\PICC\\include\
If we look in the header file for your particular chip we find:
// Configuration mask definitions
// Config Register: CONFIG1
#define CONFIG1 0x8007
// Oscillator Selection
// ECH, External Clock, High Power Mode (4-32 MHz): device clock supplied to CLKIN pin
#define FOSC_ECH 0xFFFF
// ECM, External Clock, Medium Power Mode (0.5-4 MHz): device clock supplied to CLKIN pin
#define FOSC_ECM 0xFFFE
// ECL, External Clock, Low Power Mode (0-0.5 MHz): device clock supplied to CLKIN pin
#define FOSC_ECL 0xFFFD
// INTOSC oscillator: I/O function on CLKIN pin
#define FOSC_INTOSC 0xFFFC
// EXTRC oscillator: External RC circuit connected to CLKIN pin
#define FOSC_EXTRC 0xFFFB
// HS Oscillator, High-speed crystal/resonator connected between OSC1 and OSC2 pins
#define FOSC_HS 0xFFFA
// XT Oscillator, Crystal/resonator connected between OSC1 and OSC2 pins
#define FOSC_XT 0xFFF9
// LP Oscillator, Low-power crystal connected between OSC1 and OSC2 pins
#define FOSC_LP 0xFFF8
// Watchdog Timer Enable
// WDT enabled
#define WDTE_ON 0xFFFF
// WDT enabled while running and disabled in Sleep
#define WDTE_NSLEEP 0xFFF7
// WDT controlled by the SWDTEN bit in the WDTCON register
#define WDTE_SWDTEN 0xFFEF
// WDT disabled
#define WDTE_OFF 0xFFE7
// Power-up Timer Enable
// PWRT disabled
#define PWRTE_OFF 0xFFFF
// PWRT enabled
#define PWRTE_ON 0xFFDF
// MCLR Pin Function Select
// MCLR/VPP pin function is MCLR
#define MCLRE_ON 0xFFFF
// MCLR/VPP pin function is digital input
#define MCLRE_OFF 0xFFBF
// Flash Program Memory Code Protection
// Program memory code protection is disabled
#define CP_OFF 0xFFFF
// Program memory code protection is enabled
#define CP_ON 0xFF7F
// Data Memory Code Protection
// Data memory code protection is disabled
#define CPD_OFF 0xFFFF
// Data memory code protection is enabled
#define CPD_ON 0xFEFF
// Brown-out Reset Enable
// Brown-out Reset enabled
#define BOREN_ON 0xFFFF
// Brown-out Reset enabled while running and disabled in Sleep
#define BOREN_NSLEEP 0xFDFF
// Brown-out Reset controlled by the SBOREN bit in the BORCON register
#define BOREN_SBODEN 0xFBFF
// Brown-out Reset disabled
#define BOREN_OFF 0xF9FF
// Clock Out Enable
// CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin
#define CLKOUTEN_OFF 0xFFFF
// CLKOUT function is enabled on the CLKOUT pin
#define CLKOUTEN_ON 0xF7FF
// Internal/External Switchover
// Internal/External Switchover mode is enabled
#define IESO_ON 0xFFFF
// Internal/External Switchover mode is disabled
#define IESO_OFF 0xEFFF
// Fail-Safe Clock Monitor Enable
// Fail-Safe Clock Monitor is enabled
#define FCMEN_ON 0xFFFF
// Fail-Safe Clock Monitor is disabled
#define FCMEN_OFF 0xDFFF
// Config Register: CONFIG2
#define CONFIG2 0x8008
// Flash Memory Self-Write Protection
// Write protection off
#define WRT_OFF 0xFFFF
// 000h to 1FFh write protected, 200h to 1FFFh may be modified by EECON control
#define WRT_BOOT 0xFFFE
// 000h to FFFh write protected, 1000h to 1FFFh may be modified by EECON control
#define WRT_HALF 0xFFFD
// 000h to 1FFFh write protected, no addresses may be modified by EECON control
#define WRT_ALL 0xFFFC
// PLL Enable
// 4x PLL enabled
#define PLLEN_ON 0xFFFF
// 4x PLL disabled
#define PLLEN_OFF 0xFEFF
// Stack Overflow/Underflow Reset Enable
// Stack Overflow or Underflow will cause a Reset
#define STVREN_ON 0xFFFF
// Stack Overflow or Underflow will not cause a Reset
#define STVREN_OFF 0xFDFF
// Brown-out Reset Voltage Selection
// Brown-out Reset Voltage (VBOR) set to 1.9V
#define BORV_LO 0xFFFF
// Brown-out Reset Voltage (VBOR) set to 2.7V
#define BORV_HI 0xFBFF
// Low-Voltage Programming Enable
// Low-voltage programming enabled
#define LVP_ON 0xFFFF
// High-voltage on MCLR/VPP must be used for programming
#define LVP_OFF 0xDFFF
An example in the previously quoted document is:
__CONFIG(FOSC_INTOSC &WDTE_OFF & PWRTE_OFF & MCLRE_ON& CP_OFF & BOREN_OFF & CLKOUTEN_ON & IESO_OFF & FCMEN_OFF);
__CONFIG(WRT_OFF & VCAPEN_OFF & PLLEN_OFF & STVREN_OFF & LVP_OFF);
Comparing this with the above header file you can see what each configuration macro will enable/disable.
C:\Program Files (x86)\Microchip\xc8\v1.10\docs. Thanks, all! – TDL Nov 2 '12 at 18:43
