Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I have an obscure output pulse in my output waveforms for my half-adder. Is it because that the inputs are both high at 40ns? So I should slightly delay b going high after a has gone low? The time 58ns suggests this is the case because the FLEX 10k70RC240-4 has a propagation delay of approximately 20ns.
My output looks like and the pulse is at about 58ns: enter image description here
share|improve this question
up vote 4 down vote accepted
What you're seeing is a timing glitch or race condition. There's a slight difference in the time it takes for the a signal and the b signal to propagate through to the output, so if they're both changed at the same time, you can see a very short pulse at the output before it reaches the final state (which happens to be the same as the initial state for this circuit).
If you delay one of the inputs, it will make this glitch longer because you'd have a short time where the inputs are, say, both 0, instead of having (1,0) and then (0,1) as inputs. You should also realize that in reality, you might not know whether the a signal or the b is propagating faster, and it might even vary in response to temperature or other environmental factors. The simulator has probably just arbitrarily chosen one of the two inputs to process first, resulting in a glitch time equal to the simulator's minimum time step.
The usual way to deal with a glitch like this is simply not clock the result in to the next flip-flop until after all glitches have settled. Meaning, design your circuit with adequate set-up time. The fact that glitches only affect a flip-flop's output if they happen at the same time a clock edge arrives is one reason designing synchronous logic correctly is much easier than designing asynchronous logic.
share|improve this answer
discard
