I have some NE2 lamps i want to control with a signal from my car. Signal voltage is about 11 to 14 volts and isn't very clean. I also have 170vdc available to power the NE2s. I plan on using these for turn signals and high beam indicator. Components must be able to be on for long periods of time. I would like to be efficient with power due to limitation of my 170v power supply.
I do have some TIP102's laying around but fear the input voltage is too low. Is there a 12v version of these? What resistors should i use to knock it down to the appropriate voltage? I cant find much data on these lamps and use.
link|improve this question
Be careful when modifying car lighting, if that doesn't go without saying. – Thomas O Oct 4 '10 at 21:16
Thanks, I am safe because i wired the entire car. its a 1950 studebaker streetrod. If my blinkers dont operate at the correct speed i will install a solid state flasher and be set. – Ed Owens Oct 4 '10 at 21:28
feedback
1 Answer
To custom design a circuit to switch an NE-2 bulb directly from a 170V DC supply, you would need a transistor that can withstand the 170V supply voltage when off, and pass the 0.5 (or so) mA of current when on. The TIP102 you mention would have no problem with the on-current, but can only take 100V in the off state. To get some margin over that 170V you probably would want to use a transistor with a Vceo rated 200V (or better). This would be a relatively high-voltage, low-current kind of part, compared to the majority of parts that you'll find listed in Mouser or Jameco.
As an alternative, you might investigate using a solid-state relay to switch the high voltage under control of the typical 12V automotive signal.
Also, if you obtained bare NE-2 bulbs, be sure to put a limiting resistor in series with the bulbs. Ionized neon has very low resistance, so you need a resistor to keep the current under control. From 170V, using a 220K ohm resistor would give you roughly 0.75mA through the bulb, which would be a typical current for an NE-2.
link|improve this answer
Thanks What about this transister? what should i do about the input voltage? split it with resistors? – Ed Owens Oct 5 '10 at 2:03
@Ed Owens - depends a bit on the transistor, but for example, if you assume Vbe-sat of 0.8V at the base, and want to get 1mA into the base from a 12V signal, your base resistor would be (12 - 0.8)/0.001 = 11.2K ohms – JustJeff Oct 5 '10 at 2:09
Looking at the data sheet on that KSC2752, taking Vbe-sat as 2.0V at Ib of 60mA, your base resistor would be (12-2)/0.06 = 167 ohms, and would dissipate just over 600mW, so you'd need a 1W part. Since your 170V supply would only be sourcing about 80mW per NE-2, burning 600mW in what amounts to a bias resistor seems wasteful. Since the '2752 can dissipate a whole watt, and the 170V supply with 220K can't even source more than about 130mW, it might be better to operate the transistor NOT saturated, and choose a base resistor that lets the collector ride at 60 or 70V when the lamp is lit. – JustJeff Oct 5 '10 at 2:37
feedback
or
required, but never shown
