Tell me more ×
The following document describes signal conditioning circuits for Piezeoelectric sensors. I was interested in knowing which model should I use when designing signal conditioning circuit for piezelectric sensor.
http://www.ti.com/lit/an/sloa033a/sloa033a.pdf
share|improve this question
up vote 0 down vote accepted
If you can limit the load capacitance of the cable and amplifier, you can use the voltage model. This requires that no cable is involved as cables tend to add 20~30 pF/ft.
Otherwise the charge model must be used and a charge amplifier is required. This is how accelerometers work with cables from sensor to amp.
share|improve this answer
Could you provides more information, in class they said that you have to use it based on the natural frequency of the piezoelectric sensor. Sorry I wouldn't have to be asking here if the prof provided proper lectures notes. – Anonymous Nov 27 '12 at 0:39
You can find some advantages and disadvantages of the approaches here:
Piezoelectric transducers - Endevco Tech Paper
discard
