Tell me more ×
I've got the next transfer function:
$$ \frac{\hat{\alpha}}{\hat{\alpha_{ref}}} =\frac{w_n^2}{s^2+2w_n \xi s+ w_n^2} $$
Now I want to draw a step response input at height of \$\alpha_{ref}\$, where \$\xi\$ comes with differing values (i.e different graphs on the same axis for different values of \$\xi\$, and the value of \$w_n\$ depends on \$\xi\$).
How to implement this in Matlab?
Thanks in advance.
share|improve this question
1 Answer
up vote 3 down vote accepted
A not-at-all elegant way to do it is:
zeta=[...]; %your zeta values
wn = ... % calculate your wn values according to your zeta values
figure;
hold('on');
for idx = 1:length(zeta)
    % sys = tf([wn(idx)],[1 2*wn(idx)*zeta(idx) wn(idx)^2]); %system's transfer function
    % EDIT : numerator corrected
    sys = tf([wn(idx)^2],[1 2*wn(idx)*zeta(idx) wn(idx)^2]); %system's transfer function
    step(alpharef*sys);
end
share|improve this answer
Thanks it should the numerator \$wn(idx)^2\$, other than that looks ok to me. – MathematicalPhysicist Nov 18 '12 at 2:57
I haven't noticed that. Thanks for pointing it out. Edited my answer accordingly. – HebeleHododo Nov 18 '12 at 11:13
You can write hold on instead of hold('on'); – Szymon BÄ™czkowski Nov 18 '12 at 13:39
Well yeah, but I usually try to use the function syntax. I think it gives the code more consistency. Syntax documentation can be found here: mathworks.com/help/matlab/ref/syntax.html mathworks.com/help/matlab/matlab_prog/… – HebeleHododo Nov 19 '12 at 6:26
discard
