Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Most SD cards have a fairly limited life (as in maximum number of read-write cycles), and in spite of wear-levelling, for relatively frequent disk update applications, would probably fail in a year or so, with reducing effective disk space, due to bad-blocks.
What might be some of the other secondary storage solutions, for such disk-update intensive applications, which are relatively inexpensive and not slow-coaches (the USB on Raspberry Pi, isn't very fast, as we know)?
Having said that, I am considering a USB hard-disk. Since this is a wall-powered application, power is only a secondary concern.
share|improve this question
up vote 4 down vote accepted
The question is not clear about the volume of data to be stored.
  • If the volume of data actually being written in each cycle is not very high, an USB flash memory device would be a good option: Low power requirement, low cost, and write/erase cycle ratings of 10,000 (consumer grade) to >100,000 (industrial / mil-spec) for multi-level-cell (MLC) flash.
  • A Flash-based SSD typically has the same endurance per MLC as an USB flash drive, but due to a greater amount of spare cell head-room, write optimization using on-board RAM buffers in some models, and better write leveling algorithms, is often rated for 1 million to 5 million write/erase cycles for the device.
    Downside: More power required, 500 mA will often not cut it.
  • A RAM-based SSD with on-board back-up battery is an option if the application requires even higher write cycles. Very few manufacturers offer pure RAM-based SSDs any more, though that was the primary early SSD technology. Write cycles are essentially infinite in comparison to the above options.
    Downside: Most RAM SSDs are not USB but PCI or PCIe, so an adapter is needed, as well as external power.
  • Finally, there is of course the conventional magnetic storage external hard drive with USB interface. Lowest cost per gigabyte, and very high write/erase cycles.
    Downside: External power needed, and they are sensitive to physical shock.
share|improve this answer
Excellent and very informative answer @Anindo. A 1+ and a good 'accept' candidate (will wait a bit). The volume of data written would touch a peak of about 8MB/sec for few hours a day, which is mostly write, and then a read and write (erase) cycle about 12 hours later. In a nutshell, what gets written, gets erased, after about 12hours. – icarus74 Nov 19 '12 at 8:41
@icarus74 That works out to barely 700-odd write cycles (per MLC) per annum, not at all withing a concern range. USB flash would work excellently. – Anindo Ghosh Nov 19 '12 at 9:07
Actually, I forgot to mention, one very important aspect, i.e. the average file size, which is about 80KB each, and in my calculation I think I made an equally big blunder, i.e. forgot about buffering, which is why I was getting a very large no. of writes, i.e. 80K/year. – icarus74 Nov 19 '12 at 9:36
@icarus74 You need to be calculating writes per cell per year, not overall writes per year. Hence, 80 kilobytes written to 80 k individual MLCs is merely 1 write/erase cycle. – Anindo Ghosh Nov 19 '12 at 9:46
You don't have any high-speed connectivity options other than USB 2.0 (480Mbit) and Fast Ethernet (100Mbit). Just on those specs alone I'd say go for USB.
Thanks Jim. My only worry with USB storage is most of them require more than 500mA, which means that I'd probably have to add a powered (active) hub. Not too much problem though - just that it increases the overall size of the solution. – icarus74 Nov 19 '12 at 6:32
An SSD may require less. You're basically limited to either a hard drive or SSD for large storage, so you won't be able to avoid that. The communications medium isn't what's taking the power in that case. – Jim Paris Nov 19 '12 at 6:45
discard
