Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I needed some advice on my first ever PCB. I am trying to build the circuit below (schematic drawn using OrCAD Capture), which is straight out of the datasheet of the flyback controller LT3748.
Schematic
I did some reading (including some of the posts on this forum), and decided to adopt this plan:
  1. 2-layer PCB: All components/tracks go on top, bottom layer has ground plan only
  2. All components are surface mount only.
Ok so my first attempt on the PCB is below (using the ExpressPCB software). This is a class project and we must build our own transformer. We couldn't get the bobbin we wanted and so decided to just lay down the transformer somewhere next to the board and connected it through a 4-pin connector.
First_PCB
We couldn't really mimic the layout suggested in the datasheet, as we're using only a 2-layer design for various reasons. We do realize that a 4-layer design along with a small commercial SMT transformer would have been ideal, but we're working with what we've got.
So based on some of the feedback below (and thanks to everyone who commented), I've made slight improvements to the PCB (as shown below).
I also have some questions:
  1. The datasheet advises to isolate or physically separate the high current ground from small-signal ground. The secondary ground is completely separate, so that's done with. As for primary, the only high-current grounds are those of Vin and R8 (the sense resistor). So, is it a good idea to connect the negative terminals of Vin and R8 with a track and then connect that track at one point to a ground plane that will have all the other small-signal grounds. The only penalty then would be that the R8 to Vin track would be quite long (since I'm using 2-layer only and wouldn't like to break my ground plane underneath, unless it is less worse than running this long track).
  2. As you see from the schematic, I'm running two tracks underneath the IC (i.e. on the same top layer). Do you foresee any problems there? My IC shouldn't get hot, as it works with small current only.
share|improve this question
Is there any reason you didn't try and follow the layout proposed by the datasheet? – Toby Lawrence Nov 20 '12 at 14:40
Hi Toby. I have updated my post, mentioning that two constraints I'm working with are the external transformer and 2-layer design. See my comments on Brandon's reply below. I have also posted a (hopefully) improved PCB design... – Ahmed Shehada Nov 26 '12 at 2:18
It is a pretty low parts count design, but it is by no means simple. It helps to understand how the chip works inside to see what pins are more sensitive to stray EMI than others before doing a layout. Then you can determine where coupling to ground is useful and when it can interfere. ( This is just learning curve info not specific to your layout) Although many students use the physical layout approach, it defies logic and when you want to understand how it works, you need to use logic in your schematics not just physical layout. This is most useful when it doesn't work.
vs enter image description here
When you discover the load regulation is poor due to the layout of the external transformer in relation to RFB feedback, which schematic will you follow and how will you discover why it fails in your layout. Unfortunately what schematics do not show is the equivalent circuit of a ground plane and its coupling. This is why a more "Logical" schematic is important and rules for small inductive loops is important and coupling to ground planes. Although I concur with your aadvice given, this design will be very noisy and suffer in regulation becuase of how the boundary mode processing works inside the chip. A more reliable design will use large voltage feedback thru a tertiary winding (which they use in msome aqpplications)
It may work, but how well is the question.
EMI radiation, Load regulation, Step response and ripple are important measures of performance which are affected by this clever chip's internal processing of the current waveform using the MOSFET resistance. When it fails you can try to understand how it works. With your schematic, all you can do is see that the parts are connected to the right pin.
These basics although may seem tedius to you, they are critical to getting the perfromance offered by the chip. Layout is critical in this design because of the simplified external feedback of transient switching. I would use a small planar SMD torroidal transformer such as the one used by Linear Technology and follow their layout guidelines.
share|improve this answer
Thank you, Richman, for your advice. I have updated my post and mentioned that the external transformer and 2-layer design are two constraints I have to live with for this project. Nevertheless, in my second attempt I tried to better adhere to the datasheet advice regarding layout: 1. Shortened the C1-primary-Q1_drain-Q1_source-R8 loop - except for the final return from R8 to C1, but hope the ground plane helps in that. 2. Shortened the C2-Q1_gate-Q1_source-R8 loop. 3. R5, R7, and R8 are as close to IC as possible. Any comments? THanks – Ahmed Shehada Nov 25 '12 at 7:19
Its a pretty simple circuit and the layout looks fine. Something you might want to consider is the trace width going to C1 and C5. You do want your power and ground traces as thick as possible but depending on what method you will you populating the PCB those thick traces going to the small pads for the capacitors may absorb quite a bit of heat causing your capacitors to not reflow properly.
Thank you, Brandon. I have taken your tips into consideration in the next version above. – Ahmed Shehada Nov 25 '12 at 7:00
I would learn from the demo boards they designed. A planar SMT flyback transformer is better from Pulse is what they used with a 4 layer board with 2 inner ground planes except there is a gap between primary and secondary AC of the transformer. Strong pulsed E fields are coupled between pairs of copper layers for input DC and output DC for least EMI radiation. This will be several orders of magnitude quieter for ingress into your sub-board and nearby sensor wires. enter image description hereenter image description hereenter image description hereenter image description hereenter image description here However if you really had to go cheap on materials for this design, I would put the board far awy from sensors wires and use lots of ferrite CM chokes around the wire. enter image description here When you are starting, it is better to learn what works and then experiment with cost reductions for improvement later.
discard
