Tell me more ×
What is the best way to make a 50 volts regulated power supply? I was thinking to incorporate the LM78xx IC only to find out the maximum voltage they support is around 24 V and 1 amperes. Another possible solution is to stack/cascade Zener diodes until the equivalent voltage is around 50 V. What solution is the best and reliable, assuming we can consider cost and performance also.
PS: I will use the regulator to audio power amplifier which will draw around 1-3 A.
Input: AC 220 volts 60 Hz Output: Pre amplifier and Power Amplifier (Audio) ripple - 5% tolerance
share|improve this question
Whats the input power device? Mains, battery? – Dean Nov 21 '12 at 15:44
You need to specify a lot more than "I need a 50V regulated power supply". What is your input? (AC? DC?) What voltage range? Do you need isolation from input to output? How much ripple can you tolerate? These parameters (and many more) will dictate the correct approach to the solution. – Madmanguruman Nov 21 '12 at 16:21
This question is extremely vague and needs improvement to avoid the moderators closing it. You need to elaborate a lot more on your intended operating conditions (input, output, etc.) – Madmanguruman Nov 21 '12 at 16:22
edited, and added input and output parameters. thanks – vvavepacket Nov 21 '12 at 21:43
closed as not a real question by Madmanguruman, Nick Alexeev, Olin Lathrop, Dave Tweed, Kortuk Nov 23 '12 at 16:24
It's difficult to tell what is being asked here. This question is ambiguous, vague, incomplete, overly broad, or rhetorical and cannot be reasonably answered in its current form. For help clarifying this question so that it can be reopened, see the FAQ.
1 Answer
up vote 5 down vote accepted
While there are adjustable linear voltage regulators which can deliver up to 50 Volts, that is probably not what you are looking for. At the voltage and current ratings required, a linear regulator would need to dissipate a lot of power as heat, since presumably the regulator would be fed off a bridge-rectified output from a transformer, and efficiency for a linear regulator is not very high.
This drives the linear regulator approach out of the realms of practicality.
A better option is a switched mode / buck regulator. These generate less wasted energy or heat, due to their very high efficiency, typically between 80 and 95%. A few suitable parts do come up on a product search.
Taking this approach a step further, switched mode power boards for 50 Volts / 3 Amperes can be designed using free online tools such as TI's WeBench. This would use a buck controller (e.g. LM5116, adjustable up to 80 Volts) rather than a regulator, external MOSFETs, and other components for a complete device such as below:
50 Volt 3 Ampere SMPS
Even so, the solution remains sub-optimal as you would require a fairly large and heavy step-down transformer to bring your mains voltage down to the required levels, and to isolate the output from the power lines for safety.
Next option, an SMPS:
Mains-powered SMPS units of voltages and currents close to your requirements are available off the shelf from vendors specializing in industrial power supplies. Failing this, SMPS manufacturers can custom-build an SMPS to your required rating. I have recently had an SMPS somewhat like in the question custom built by a local manufacturer, and it worked out not nearly as expensive as I had expected.
On another note: Many DIY audio amplifiers use unregulated power supplies, consisting of a step-down transformer, a full bridge rectifier and large reservoir capacitors, for driving the power amplification stage in balanced / dual rail mode. This will typically cost much less than a custom built SMPS, and might serve the purpose with some constraints.
From a cursory search on digikey.com it appears that regulators and buck controllers for the required voltage and current ratings in your question, are all surface mount packages. Assumption: You are comfortable using SMD components in your design.
share|improve this answer
