I need to multiply 2 3bit numbers. I tried that:
but it does not seem to work.
In this example, the output should be 49. so that is that 77?
but it does not seem to work. In this example, the output should be 49. so that is that 77? |
I'm having a hard time trying to understand the schematic...however: there are several different architectures for binary multipliers, but all of them are based on simple considerations. 1- The multiplication in binary logic is made by the AND operator. Therefore you will need a battery of AND gates that multiply each bit of one factor for each bit of the other. To make it simpler, let's call the factors A and B, of M and N bits respectively. The AND product of the two numbers will give N vectors of M bits, with increasing weight. Now you have to sum up all the vectors considering the weight of each one, to obtain the result. Long story short: I see the full adders, but you first miss the AND operators. Some more info on wiki. |
