Tell me more ×
I will like to separate into different vars some information from a HTTP response, at the moment I'm just printing to the serial port the raw data, using:
Serial.print((const char*) Ethernet::buffer + off);
And that prints:
HTTP/1.1 200 OK
Date: Wed, 21 Nov 2012 22:47:21 GMT
Server: Apache
Vary: Accept-Encoding
Connection: close
Content-Type: text/html
Temp = 28...
I wonder how can I extract the information I need for later analysis, like the HTTP response code (200), the date, and the value of Temp, how can I extract this values into variables?
share|improve this question
Parsing HTTP header strings in what looks like C++ seems somewhat remote to electronic design, even if it's on an embedded board. – Kaz Nov 29 '12 at 2:11
This might be a pure software problem if it were implemented on a more capable platform, but given the extreme resource limitations of an ATMEGA328, especially when running a TCP stack, it may be necessary to code the string parsing with unusual efficiency - ie, using the standard library functions may not be wise. Though if it works and you don't need to do anything else, fine. – Chris Stratton Dec 19 '12 at 16:39
up vote 1 down vote accepted
I had a look at the documentation, and it seems that you get the HTTP response from the Ethernet library, but you need to extract the information by other means.
I see two possibilities: (a) you parse the answer using C/C++ standard functions, or (b) you use a library created by somebody else. I found two libraries that may help you: this and this. Have a look at them and tell us how it goes with them.
share|improve this answer
What @Kaz said - this is a software problem not an electronics one...
However, a good start would be to look through the nweb server source code, that's about the neatest little web server I've seen.
discard
