I am struck between the right method of biasing for BJT.I want to design a BJT power amplifier, i need maximum current at the output because of the low impedance of the load as well as adequate stability for my design.i want to know which is best between self bias and voltage divider network considering my needs for the system.
Tell me more
Electrical Engineering Stack Exchange is a question and answer site for
electronics and electrical engineering professionals, students, and enthusiasts. It's 100% free, no registration required.
closed as not a real question by Olin Lathrop, Nick Alexeev, Kaz, Dave Tweed, clabacchio♦ Nov 27 '12 at 17:25
It's difficult to tell what is being asked here. This question is ambiguous, vague, incomplete, overly broad, or rhetorical and cannot be reasonably answered in its current form. For help clarifying this question so that it can be reopened, see the FAQ.
If what you need is a low output impedance, you need an emitter follower connection. Also, if you want to make sure your circuit is insensitive to beta, then you should do a voltage divider connection (a collector feedback would work too i guess) |
