Tell me more ×
So, i'm trying to communicate with a heat sensor using SPI with a chipkit pic uno32.
I connected Pin 10 (SS), Pin 11 (DIN), Pin 12 (DOUT), and Pin 13 (CLK) on the Uno32 board to the sensor
SS-Chip Select DIN - Data Input DOUT - Data Output CLK - Clock
int i; IEC0CLR=0xFFFFFFFF; // disable all interrupts
SPI1CON=0; //desliga SPI
SPI1BUF=0; //limpa buffer
SPI1BRG=0x1; // use FPB/4 clock frequency
SPI1STATCLR=0x40; //limpa bit SPIROV
SPI1CONSET=0x0520; // 16 BITS | FALLING EDGE | Master Mode
SPI1CONSET=0x8000; //liga SPI
SPI1BUF=0x10; // transmit an A characte
while(SPI1STAT & BUSY)
    write_str("A receber\n\r");
printf("%d\n\r",SPI1BUF);
The printf and write_str function works and sends data trough serial port (UART). So when i put something in the buffer its supposed to transmit that data and receive the data from the sensor, in this case the temperature (value with 10 bits). However i always get the value 0 (which corresponds to 0 degress celcius which is incorrect).
Need help,
Thanks
share|improve this question
1 Answer
Look up the && operator in your C reference manual, and how it differs from &.
share|improve this answer
Nice catch.. +1 – m.Alin Nov 28 '12 at 1:21
I forgot about that, so i fixed it and updated my code. Now i get the SPI1BUF register completely filled with 1's. Also i cheked the wiring and correted it, i had Din connected to the sensor's DIn and should be PIC DOUT to the Sensor's DIN – cr4zypt Nov 28 '12 at 10:36
discard
