I'm trying to avoid soldering or modding of any kind as I'm 7,000 miles away from where the project is based! I'm trying to come up with a simple solution I can get a layman to do on my behalf. I have the following IO board: http://www.phatio.com/ which exposes 2x14 IO ports (2.54mm pitch pin header connection) but need to convert the connections into screw terminal block type.
I was thinking of using some angled double pin header connectors and then connecting them to pluggable screw terminal blocks (http://www.metz-connect.com/en/products/311661) but the smallest size I can find is 3.5mm.
Anyone have any suggestions or a better/alternative idea? (screw terminal blocks are a must)
Thanks
