Tell me more ×
I'm thinking about building a simple electronic watch in my spare time.
Not a lot of functions, no LCD, just keeping time and displaying the time using LEDs.
However, I have never created a time-keeping circuit so I'm wondering if using a µC's internal clock is enough to keep track of time or do I need something else?
I have seen some people using 32.xxkHz for time-keeping. Why do people choose this particular value (maybe it's just coincidence I came across a few projects using that value).
Links to projects are always welcome.
share|improve this question
32768Hz divide by 2 = 16384; 16384 / 2 = 8192; 8192 / 2 = 4096; 4096 / 2 = 2048; 2048 / 2 = 1024; 1024 / 2 = 512; 512 / 2 = 256; 256 / 2 = 128; 128 / 2 = 64; 64 / 2 = 32; 32 / 2 = 16; 16 / 2 = 8; 8 / 2 = 4; 4 / 2 = 2; 2 / 2 = 1. And dividing by two is very easy in an electronic circuit. Basically what can be done is divide 32768 by 2^15 to get 1Hz. – jippie Dec 14 '12 at 22:48
I should have noticed. Thank you! – Delusion Dec 14 '12 at 22:54
There are 365 days * 24 hours * 60 minutes = 525600 minutes in a year. If you want at most 1 minute deviation per year then you want at max 100% / ( 365 * 24 * 60 ) = 0.000190% frequency fault. An internal RC oscillator in a microcontroller doesn't even come close. More commonly this is represented as (approx) 2 ppm (parts per million). – jippie Dec 14 '12 at 22:56
Thank you. You don't happen to know a website where I can read up on this stuff? – Delusion Dec 14 '12 at 23:00
@Delusion Here's Atmel's real time clock app note atmel.com/Images/doc1259.pdf it may help you understand what's happening. – Garrett Fogerlie Dec 15 '12 at 2:19
show 1 more comment
up vote 5 down vote accepted
32.768 kHz is used in watches for two reasons:
  1. It's a power of two, so it can be divided down to 1.000 Hz with a simple, binary divider.
  2. It's a relatively low frequency that can still be put in a tiny package. The low frequency keeps the power consumption in the IC low.
share|improve this answer
Thank you! One step closer. – Delusion Dec 14 '12 at 22:57
32.768 kHz divided by 2^15 is 1 second. And since that is a standard frequency and a very high volume part, they are dirt cheep.
I would interface the micro with an RTC (Real time clock)
https://www.sparkfun.com/products/99
discard
