Tell me more ×
I understand a cache memory is constructed for a basic block like this
Valid bit | Address bits | Data/Instruction
But what determines the length of the address bits? I understand that for a 32-bit system the address bits always end with two zeroes and therefore these two zeroes are omitted. Will for 64 bits last 4 digits be zero? Does this depend on size of primary memory? What does the formula look like?
share|improve this question
up vote 2 down vote accepted
Data is stored in caches in the form of "lines". Each line could be just one byte or just one 32-bit word, but usually, it's a much larger amount, such as 32 words (128 bytes) — often matched to the maximum "burst" size available from the primary (DDR SDRAM) memory.
Also, most caches have a limited amount of "associativity", which is another way of saying that the data from a particular address can only be stored in a limited number of places in the cache. In modern CPUs, 4-way and 8-way associativity are common, as this gives a good balance between performance and complexity.
If you have a 1-MB cache that has 128-byte lines, that means you have 8K lines in the cache. If you have 8-way associativity, that means that the lines are broken up into 1K groups of 8. The group number is usually defined by the low-order address bits for that particular line of memory. In this case, 10 bits would be required to index the cache.
The address bits stored with each line are called the "tag", and the tag is used to decide whether the address currently being requested by the CPU is being held in that line of the cache.
The number of bits required in the tag is simply the number of address bits coming out of the CPU (virtual address bits for a virtual cache, physical address bits for a physical cache), minus log2 the cache line size (i.e., the number of bits required to address a byte within a line), minus log2 the number of line groups in the cache (the number of bits required to select an associativity group).
For example, if you have a physical address space of 4 GB (32 address bits), and a 1 MB, 8-way cache with a line size of 128 B (7 address bits), the tags would need 32 - 7 - 10 = 15 bits.
share|improve this answer
The reason why the last two bits can be ignored is that memory is allocated and aligned by operating systems and language compilers and runtime systems on at least 4-byte boundaries. It doesn't have anything specific to do with the number of address bits.
discard
