Tell me more ×
I have the next system, and I want to find the transfer function from d to y.
So I've got the next equations
v = Ce = C(r-y)
e = r - y
u = d + v
y = Pu = Pd + PCr - PCy
Now I know that:
\$e/r = \frac{1}{1+PC}\$
So eventaully if I am not mistaken I arrive at:
$$y/d = \frac{P}{1+PC}+\frac{PC}{1+PC} \frac{r}{d}$$
How do I eliminate the dependence on \$r/d\$? i.e, I want y/d to be a function of P and C.
Thanks in advance.
Edit: actually, I arrive at:
$$ y = \frac{P}{1+PC} d + \frac{PC}{1+PC} r$$
So the transfer function from d to y should be: \$P/(1+PC)\$, correct?
share|improve this question
If you want to find the transfer function of y/d you have to ignore r, ie, set it to 0. It has no place in the y/d transfer function. – AngryEE Dec 17 '12 at 19:07
1 Answer
$$ y = \frac{P}{1+PC} d + \frac{PC}{1+PC} r $$ r is desired input and d is disturbance so we have to reduce effect of d if gain of C picked big so we have: $$ if \space C \uparrow \hspace{8 mm} \frac{P}{1+PC} \downarrow \hspace{8mm} and \hspace{8mm} \frac{PC}{1+PC} \simeq 1 $$ so $$ y \rightarrow r $$ warning : be careful about stability.if C picked very big stability of system would be at risk
share|improve this answer
discard
