Tell me more ×
LEDs are often connected through a resistor and the purpose of this seems to be to lower the voltage across the LED to around 1.8V. Can PWM be used to lower the voltage instead of a resistor? If so, what is a reasonable frequency to avoid burning out the LED?
My actual application is to connect an optocoupler directly to a micro controller but I figured that most people will be more familiar with LEDs and the answer will be the same.
This "experiment" would answer my question but he never posted his results.
share|improve this question
up vote 4 down vote accepted
The current drawn by an LED (or any diode) rises exponentially as a function of voltage, with the typical forward voltage being the onset of exponential growth. Because of this, it's more important to think of your LEDs or optocouplers as devices that require a constant current, rather than a specific voltage. You want to stay away from that exponential curve, not just to protect the LED, but also to protect your microcontroller from sourcing or sinking too much current.
Sometimes, you get lucky and the microcontroller's internal output pin resistance is just enough to limit current through a particular LED. Sometimes it works out better in current sinking configuration. Check your datasheets.
Resistors are used to set a current limit. Higher power LEDs, particularly those used for illumination, may be driven by a constant current regulator to avoid flicker due to slight variations in the voltage supply. The exponential function magnifies small changes.
Resistors are cheaper than dirt, so it's easier to put them in where they are needed than find a workaround. If your time is worth anything, you could buy several hundred resistors by the time you've set up your PWM test. The experiment you reference is not really thought out. Rather than guess at arbitrary PWM values, it would seem reasonable to conjecture that if the total energy delivered to the LED is less than the forward voltage * maximum sustained LED current per PWM cycle,
$$ {1 \over T}\int_0^T V_{pwm}(t)I_{pwm}(t)\,\mathrm{d}t < {V_{forward} I_{max}} $$
it's probably safe(-ish), but there still may be problems from the brief high current peaks.
If someone told me they did that experiment in a job interview, I'd show him/her the door. It's not worth the trouble.
By the way, neither PWMs nor their frequency lower voltages. The duty cycle reduces the power transmitted. Increasing frequency allows more precise control, but it's really the duty cycle that does the work.
share|improve this answer
LED's can be approximated within 10% by the threshold voltage and ESR.. same with CMOS drivers and BJT drivers above saturation so using PWM is OK on discrete LEDs but not specified and hence not OK in this part. This 300 LED string using small Rs in seris with ESR of LED is an example of linear V vs I above threshold. not exponential due to ESR. which is significantly more linear than PN junction variation.. also it is why LED's make better Zeners than silicon due to lower ESR... compare with any Zener V vs I if you wish to understand and any LED V vs I curve beyond average I rated. – Tony Stewart Dec 20 '12 at 16:13
It is a steep linear curve above threshold voltage. until loss of efficacy of LED for IV...is reached. and self heating affects Voltage drop as it did with the spikes and negative delta slope (ESR) in OP's VI curve.. – Tony Stewart Dec 20 '12 at 16:16
The obvious reason for a PWM current regulated design without resistors is that resistors waste power. In a battery powered device, that is to be minimized. – Chris Stratton Dec 20 '12 at 16:30
In general, NO. The current without a resistor (or other current limiting) is 'out of control', and some fraction of that is still 'out of control'.
Side note: the peak current allowed for normal LEDs is often only a little above the rated current (for instance 30 mA versus 20 mA), so even when you PWM with a controlled current do check the LED datasheet.
Not easily. The resistor gives immediate and automatic control of the LED current. PWM effectively controls mean voltage, so it would require you to measure the actual current (how? by measuring the voltage across a ... ah, resistor!) and controlling the PWM ratio to set the current. Much more complex!
You could use a low value resistor to limit the current to a reasonable value - say 20ma (the upper limit for a typical LED) and PWM down from that...
Not too complex if you can measure the effective linear resistance (ESR) of driver and LED to estimate current limit is linear with voltage above threshold... I can prove with sufficent space & time... but..that's why most engineers use CC sources for LED's but CV sources with tolerance control can be used with controlled ESR. ( elaboration required to specify parts and limits.) – Tony Stewart Dec 20 '12 at 16:18
Would that be good enough (say, better than 2:1 current ratio) without taking temperature dependent effects and LED self-heating into consideration? – Brian Drummond Dec 20 '12 at 16:50
discard
