Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I'm aware that nobody actually does this at the hobbyist level, that successful commercial products have been launched without certification, and it's probably something I can't afford if I have to ask. However, I've always wondered about the ballpark cost. About how much does it cost to receive FCC certification?
share|improve this question
I will look up how much we paid for this last time we did it. It is reasonable, but it is not cheap. – Kortuk Oct 14 '10 at 15:16
Are you referring to a device that has a wireless module in it, or are you just concerned about EMC/EMI testing? – tcrosley Oct 14 '10 at 15:26
@Kortuk I am only looking for a ballpark figure. @tcrosley let's stick to unintentional radiators for now. – joeforker Oct 14 '10 at 16:16
let me ask the company, i am not at work and do not handle accounting so i cannot even remember ballpark. – Kortuk Oct 14 '10 at 16:28
up vote 31 down vote accepted
As a rough estimate, the cost is $10k-20k, plus your labor cost.
In the US, all products containing electronics that oscillate above 9 kHz must be certified. The law that governs this is FCC Part 15. The lawyers call this "Title 47 CFR Part 15," meaning that it is the 15th subsection of the 47th section of the Code of Federal Regulations. In Europe, there is a similar regulation called CISPR 22. The requirements are almost the same, but slightly stricter about emissions at certain frequencies.
You can read 47 CFR 15 online. It's not as incomprehensible as you might expect. It seems overwhelming, but if you read the first few PDF's, you'll realize that most of it irrelevant for any single product.
Within 47 CFR 15, there are two classes of testing: Class A and Class B. Class A is an easier test to pass, intended for devices that are used in industrial settings. Class B is stricter, intended for devices that are targeted at consumers.
There is additional testing for "intentional radiators," meaning radios, Wi-fi, Bluetooth and such. There may be an exception if your device is intended for use as a component in a larger system (like a microprocessor or memory card in a PC), but I'm not sure of the legal details there.
The major expense is renting the test chamber. This is what's called an "anechoic chamber," instrumented with a pile of sensors for detecting electromagnetic radiation. To my knowledge, these cost around $1000/hour, and each testing session takes 2 or 3 hours. It's unlikely, but not impossible, that you will pass on the first try.
Here's a decent picture of a test chamber. The one I've been in was actually much larger, like a squash court. I think it was an Intertek facility in Menlo Park, CA.
Unless you're experienced with emissions testing, it is worth hiring an expert, which costs around $500/hour. They can tell you things like, "Put a ferrite bead on that power cable, and that will reduce the emissions at this frequency." The folks I've worked with arrive with a bunch of ferrite beads and inductors (and maybe caps?) of various sizes that you can use in the chamber to hack your device into compliance.
(Perhaps it goes without saying, but I'm an engineer, not a lawyer. I have taken a few products through Part 15, but not in the last couple of years.)
If you're thinking about doing this, start by reading EMC for Product Designers by Tim Williams. I'd avoid the books by Mark I. Montrose; I found them less helpful and more expensive.
share|improve this answer
About five years ago I got a product CE tested for $7500. The testing house provided advice, and they retested until it passed as part of the upfront cost. It passed on the second attempt (barely). Since, I've read High-Speed Digital Design: A handbook of black magic several times until I mostly got it and I probably won't have nearly as much trouble in the future. I highly recommend the book.
Always a good idea. High-speed Digital Design is one of the best books I have ever read for applied EM theory, just don't tell my professors. – Kortuk Oct 14 '10 at 23:58
Where I used to work we saved a lot of money on CE testing by hiring the facility for half a day and doing our own preliminary testing. We fixed any problems, they were usually quite minor, and the equipment always then passed first time. You do need to have someone who knows how to drive the test instruments, of course.
the university has a facility we are trying to rent in town for the same reason. – Kortuk Oct 14 '10 at 16:29
discard
