Tell me more ×
I've been having a common reoccurring issue when I write VHDL code. I end up writing code similar to this (as an example):
ENTITY registerfile IS
    PORT(VX : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
         RS1: IN  STD_LOGIC_VECTOR(3 DOWNTO 0));
END registerfile;
ARCHITECTURE rtl OF registerfile IS
    TYPE FeedbackSignal IS ARRAY(15 DOWNTO 0) OF STD_LOGIC_VECTOR(7 DOWNTO 0);
    SIGNAL V_F : FeedbackSignal;
BEGIN
    PROCESS(RS1, V_F)
    BEGIN
        CASE RS1 IS
            WHEN "0000" =>
                VX <= V_F(0);
            WHEN "0001" =>
                VX <= V_F(1);
            WHEN "0010" =>
                VX <= V_F(2);
            WHEN "0011" =>
                VX <= V_F(3);
            WHEN "0100" =>
                VX <= V_F(4);
            WHEN "0101" =>
                VX <= V_F(5);
            WHEN "0110" =>
                VX <= V_F(6);
            WHEN "0111" =>
                VX <= V_F(7);
            WHEN "1000" =>
                VX <= V_F(8);
            WHEN "1001" =>
                VX <= V_F(9);
            WHEN "1010" =>
                VX <= V_F(10);
            WHEN "1011" =>
                VX <= V_F(11);
            WHEN "1100" =>
                VX <= V_F(12);
            WHEN "1101" =>
                VX <= V_F(13);
            WHEN "1110" =>
                VX <= V_F(14);
            WHEN "1111" =>
                VX <= V_F(15);
            WHEN OTHERS =>
                VX <= (OTHERS => 'Z');
        END CASE;
    END PROCESS;
END rtl;
Assume V_F is connected to an internal register or something similar. I feel like this is extremely repetitive, and I can't seem to figure out a better way. Is there a more concise way similar to something like:
VX <= V_F(RS1);
share|improve this question
up vote 3 down vote accepted
I have resolved this issue myself in a different, more compact way.
I have essentially used the following:
PROCESS(RS1, V_F)
BEGIN
    VX <= V_F(TO_INTEGER(UNSIGNED(RS1)));
END PROCESS;
share|improve this answer
I've done this myself and it was supported by ModelSIM and Xilinx ISE. – Aaron D. Marasco Dec 23 '12 at 0:02
It looks like this is one of those occasions where a loop works very well:
if (RS1 > 15) then
    VX <= (others => 'Z';
end if;
for i in 0 to 15 loop
    if RS1 = i then
        VX <= V_F(i);
    end if;
end loop
I've used these constructs for expanding 8-bit FIFOs to 32-bit data buses and also for implementing register reads for arrays of similar components (e.g. 8 identical serial ports with their register sets in a contiguous block of I/O memory).
Oooh not a bad idea. I don't think your code works as is though. Wouldn't you need to convert i to a 4 bit STD_LOGIC_VECTOR? – Nick Halden Dec 22 '12 at 23:02
Seems to work fine in Quartus. – Andrew Kohlsmith Dec 23 '12 at 0:36
If it "works", that means you're using those non-standard STD_LOGIC_ARITH libraries and you'll never quite be sure of what you're getting or why... Use numeric_std, and declare RS1 as unsigned. The loop is a very useful technique, but unnecessary in this specific case; you can use TO_INTEGER and address the bits directly. – Brian Drummond Dec 23 '12 at 10:04
@BrianDrummond no, I don't ever use std_logic_arith. std_logic_1164 and numeric_std only. – Andrew Kohlsmith Dec 23 '12 at 15:04
VX <= V_F(RS1);
won't work since vector indicies must be determinable at compile-time (for concurrent statements).
Instead, the most compact way of describing the behaviour you want is to use sequential statements. Look at Kohlsmith's suggestion.
discard
