Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
A 1MW power plant producing power constantly for 24 hours will produce 24 MWh a day. Is that right?
If it is, I don't understand when it says, in http://www.beaconpower.com/files/Flywheel_FR-Fact-Sheet.pdf, that the 20MW energy storage plant can release 25kWh at 100kW for 5 minutes.
What does that mean? I don't get why they refer the plant as having 20MW, when all it can do is release 25kWh at 100kW for 5 minutes. Also isn't 25kWh over 5 minutes at a rate of 300kW?
share|improve this question
Fisrt take a look at this sentence:A 20 MW energy storage plant consists of 200 such flywheels. So 20*100 kW=2 MW Next take a look at the calculation itself. The device can deliver 25 kWh of energy and can deliver 100 kW for 15 minutes. 60/15=4, so 100 kW* 1h/4=25 kWh. Everything looks fine to me. – AndrejaKo Dec 27 '12 at 7:21
Ahh... I don't know why I read it as "5 minutes"... Thanks for clearing it up! – Eric Dec 27 '12 at 7:23
up vote 4 down vote accepted
A watt (or kilowatt or megawatt) is a measure of power. Power is the rate of energy transfer. For example, a watt is defined as 1 joule per second, where you can think of a joule as one nicely measured packet of energy.
Watt-hours (or kilowatt-hours or megawatt-hours) is just another way of measuring energy. A kWh is one kW of power flowing for one hour, which is 1000 joules going by every second for one hour. Since there are 3600 seconds in a hour, 1 kWh is therefore exactly the same as 3.6 Mj. The electric grid deals with large power levels and large energy transfers, so that discipline has evolved to express energy in MWh and kWh because that is more directly relevant to how they transfer and store energy.
I didn't look at your link, but what I remember from the Beacon Power flywheels is that each one is rated for 100 kWh. The 100 kWh is stored by spinning large and heavy flywheels in vacuum on magnetic bearings. During normal operation, the flywheel speed goes from its maximum to half that, which means from full to 1/4 of the flywheel's total energy. If I remember right, the 100 kWh figure is the difference between the two normal operating extremes.
I think the discrepancy between 20 MW and the 100 kWh of individual flywheels is that they are referring to a large plant with many flywheels.
25 kWh transferred over 5 minutes is 25 kWh transferred over 1/12 hour, which is 300 kW continuously for 1/12 hour. So yes, your last sentence is correct.
share|improve this answer
Think of it as speed versus distance. Watts measure the rate of energy use (analogous to speed) while watt hours measure the amount of energy used (distance traveled.)
You can consume 100 Wh by using 1Watt for 100 hours or by using 100 Watts for 1 hour. Just like you could travel 100 miles at 1mph or 100 mph.
discard
