I need to do some communication between 8051 micro-controller and PC . There used to be a hyper terminal for this purpose in windows XP. I m using windows 8 now. So can anyone suggest me some equivalent of hyper terminal in windows 8 for the purpose of serial comm. between micro-controller and PC.
PuTTY, surprisingly enough, can act as a full-featured serial terminal. It supports full-blown VT-102/VT-80 command codes too. There is Termite, which is a very nice, no-installation 200K exe: Parallax also has a nice serial terminal. |
I'll just add TeraTerm in and hTerm in case you're really going low-level, but mainly I use PuTTY. |
RealTerm is also useful program..
I like Terminal. It has a very easy to use interface, macro capability, and quick graphing tools. |
HTerm is a gem! I've used this on WinXP and Win7 without problems.
I generally use RealTerm. However I have had problems sometimes with it locking up in Windows 7, particularly with virtual COM ports like USB. So I got a copy of HyperTerminal Private Edition, by Hilgraeve Inc. which is the company that wrote the original HyperTerminal for Microsoft. They indicate it works with Windows 7, 8, and Vista. As others have said, it isn't that great a terminal program but it was able to connect to a virtual COM port in Windows 7 on a development board that RealTerm was unable to. |
