Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I am having problems diagnosing the error with a notebook LCD display inverter.
Symptoms: After switching the notebook on, the LCD backlight comes on but the intensity oscillates rapidly (flickers). After about 1 second the backlight turns off completely. Once the backlight has turned off, the AC output of the inverter measured with a DVM is 0 Vac.
I visually checked the inverter board and there are no obvious faults.
Given the symptoms, can anybody venture a guess at the problem?
  • On the one hand I am tempted to say that the backlight is ok (after all it ignites) and the problem is more likely to lie with the inverter.
  • On the other hand I am wondering whether the flickering of the bulb (faulty bulb?) causes a open-circuit protection of the inverter to kick in after 1 second.
So in summary I am not quite sure whether the fault is more likely to lie with the bulb or the inverter.
share|improve this question
Is the backlight a cold cathode fluorescent tube (CCFT)? – JYelton Jan 2 '13 at 20:26
@JYelton I believe so but have not taken everything apart. CCFT is the standard for LCD notebook backlights however, no? – ARF Jan 2 '13 at 20:39
Repair questions are off-topic. – Leon Heller Jan 2 '13 at 20:44
@LeonHeller Point taken. I have remove the repair component from the question and focused on the fault diagnosis procedure to make the question and its answers transferable to other situations with LCD backlight issues. – ARF Jan 2 '13 at 20:51
@Arik Not necessarily, there's also LED backlights, but they wouldn't require an inverter. – JYelton Jan 2 '13 at 20:56
Just be aware that there are potentially very high voltages on board the inverter. Be careful.
It is entirely possible that you'll be able to find a replacement part from another laptop. There are a few common suppliers that multiple manufacturers used. Look to a laptop supply place in your area for leads and supplies. Here I am referring to both the CCFL and the inverter.
share|improve this answer
Thanks for the warning about the high voltage. It is one of the reason why my fault-finding efforts were fairly rudimentary. I did not want to fry my DVM... Regarding replacement: Sumida is a very common supplier. My primary concern is that I do not know to what extent voltages and current requirements of backlights in different laptops are comparable. Also, as already mentioned, there is the issue of the 4 IO(?) pins. – ARF Jan 2 '13 at 20:43
@Arik You may want to look for a similar or exact model laptop with a cracked screen or dead motherboard, and see if you can extract working backlight parts from it. – JYelton Jan 2 '13 at 20:57
@JYelton Good idea, unfortunately it is a rare model (about 1 on Ebay worldwide every few months). Maybe I will get lucky... – ARF Jan 2 '13 at 22:53
+1 for the suggestion to replacement. It's called fault isolation method in troubleshooting. However this could not be a final accepted answer. Because I mean it's all about symptoms and root cases. – Standard Sandun Sep 30 '13 at 10:34
Most probably this is due to electronic dieseling issue. I'm not aware of this, but electriciantalk.com/f2/… – Standard Sandun Sep 30 '13 at 10:50
discard
