I have some relative experience on AVR but just minimum with PICs. In order to start a project I've just wanted to verify that I was able to get the internal oscillator working at the right frequency. So, my first test was to toggle a pin and see the frequency I've got. The first test code was
#include <p24F16KA102.h>
_FOSCSEL(FNOSC_FRCDIV & FNOSC_PRI );
_FOSC( POSCMOD_HS );
int main(void)
AD1PCFG = 0xffff; //make ADC pins all digital
TRISA = 0; //Make all PORTAs all outputs
while (1)
LATAbits.LATA6= ~LATAbits.LATA6;
return 0;
The frequency measured on the RA6 is about 59 KHZ. This looked crazy out of a 8MHZ clock. It seems to be that LATAbits and the negation requires 14 Instructions !!
So I've searched on the internet in order to minimize the instructions to just toggle a pin and found out a built in assembly of BTG so I've repeated the above code replacing the LATAbits with
__builtin_btg(&LATA, 6);
Now the dissasembly shows there are 3 instruction to execute the loop and the toggling
029A 202C40 mov.w #0x2c4,0x0000
029C A26010 btg [0x0000],#6
029E 37FFFD bra 0x00029a
Now the frequency at PIN RA6 is 201 KHZ !!!
What am I doing wrong here ??? I've tried the configuration bits from the MPLAB without the code etc etc . Is this OK ? an 8MHZ clock will produce 201KHZ as the best option to toggle a PIN?
It is very likely I am doing something wrong hence why I decided to post this here after spending more than 6 hours trying.
From datasheets I know that each instruction requires 4 clock cycles but I am not sure on instruction cycles, clock cycles and execution cycles. I will appreciate any help or guidance. Perhaps I am more used to 8 bits where the ratio to clock cycles is smaller. What is the easiest and safe way to verify the clock frequency?
OK Thanks everyone for all the answers as all of them gave me a direction to follow. I have just tested the suggestions from Olin and Madmanguruman. As I did not find a direct way to put inline asm having address tags like loop: below, I've created a file test1.s with one function called loop1 with the code given by Olin below and just called it as shown in the code below:
extern int loop1(void);
int main(void)
loop1();
return 0;
Now the measured frequency at RA6 is about 335 KHZ. The loop is run every 1.47 microseconds (670 KHZ). This is, of course, double the frequency above as the scope actually measures two loop cycles, the one RA6 is high plus the one RA6 is low.
Then using the info from Olin below the clock rate should be 12 X 680KHZ = 8.16MHZ.
The only thing I am not 100% clear is how the frequency of the instructions is defined, i.e, should I have the time RA6 is high (or low) as the period?, then 1 instruction seems to be 2 ck cycles or.. should I use the time RA6 is high, then low , then back to high as the period? in this case then it should be 4 ck cycles per instruction.
Above is a matter of definition. My main question is answered as ( thank to all your help from this forum) I am positive the CK must be 8 MHZ, then, I know the maximum possible frequency toggling a port PIN is about 335 KHZ with the ck at 8MHZ ( here I mean the standard definition of frequency). Also, using the PLL I can be able to duplicate or cuadruplicate that rate.
