Tell me more ×
Possible Duplicate:
What exactly does a diode do?
What happens in a diode to make current only flow one way around a circuit? My physics teacher said it was something to do with the metals in it and the impurities in them. Can anyone give me a detailed explanation. Any help much appreciated.
share|improve this question
Some demonstration of basic research would be nice. – Phil Frost Jan 14 at 14:07
marked as duplicate by Leon Heller, Dave Tweed, Anindo Ghosh, Brian Carlton, Nick Alexeev Jan 14 at 20:10
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
This is probably better off asked on the physics stack, but essentially:
You have two differently doped semiconductors, one P-type and one N-type. The N-type has excess electrons, and the P-type has excess "holes" (which means the absence of an electron in an electron shell)
When you bring the P and N type materials together, you form a P-N junction. At the junction, some of the excess electrons cross over and fill the holes in the P-type material, forming a depletion zone (essentially a built in potential):
Depletion zone
This depletion zone is (almost) non-conductive, as it has no free charge carriers. Now if we apply a potential (voltage) across the junction, depending on the polarity, the depletion zone either widens or narrows. If the region widens, the non-conductive region increases and no current can flow through the diode.
Widening zone
If it narrows, at a certain potential (~0.7V for a silicon diode) the diode will begin to conduct. This (hopefully) explains why the diode acts in the way it does.
Narrowing zone
Above images from this introduction to diodes.
Also, this image (from the Wikipedia P-N Junction link above) shows the P-N junction with a little more information than the above images:
Wiki P-N Junction
share|improve this answer
Refer-Diode.
It has two sides . 1.P-side(more holes and so more positive charge)
2.N-side(more electrons and so more negative charges).
Hence on joining these two sides together,you will get solid state with a junction at joining side.![enter image description here][2]
For more information see the Video
The Preparation of P-side and N-side is done by adding impurities to the germanium or silicon
For p-type-trivalent impurities are added
For n-type-pentavalent impurities are added
