Take the 2-minute tour ×
Why xbee communication is not satisfied, I do not understand. The reason is like complicated. Can you help me ?
I have send data as ;
TXREG = 'e';
I have xbee coordinator connected via usb to my desktop. In it, python xbee api works.
In the pic development kit I have connected regulated to the rs435, extension socket, dout/in pins. On regulated, xbee end point.
|                      |          |   TX RX GND VCC |
| DIN DOUT RA3 GND VCC |          |                 |
| RC5 RC5 RC2  SCL SDA |          |                 |
     extension socket                 regulated
I have configured my xbee coordinator as ;
57600
api mode
destination address dl = ffff dh = 0
I have configured my xbee end point as ;
57600 baud rate
at mode
destination address is coordinator address
I have configured Pic18f4520 as ;
FSR0H = 0;
FSR0L = 0;
/* User setting : actual PIC frequency */
Tmr0.lt = _20MHZ;
/* Timer OFF - Enabled by Kernel */
T0CON = 0x08;
TMR0H = Tmr0.bt[1];
TMR0L = Tmr0.bt[0];
/* configure ADC unit */
TRISD = 0;
TRISA = 1 ;
ADCON0bits.CHS2  = 0;
ADCON0bits.CHS1  = 0;
ADCON0bits.CHS0  = 0;
ADCON2bits.ADCS1 = 1;
ADCON2bits.ADCS0 = 1;
ADCON2bits.ADFM  = 1;
ADCON1bits.PCFG0 = 0;
ADCON1bits.PCFG1 = 1;
ADCON1bits.PCFG2 = 0;
ADCON1bits.PCFG3 = 0;
ADCON0bits.ADON  = 1;
                        // set all ports of PortD as output
TRISE = 0;              // set all ports of PortE as output
PORTD = 0;
PORTE = 0;              // clear PortE
/* configure USART transmitter/receiver */
SPBRG = 21;             // for 20 MHz, to have 57600 baud rate, it should be 21
TXSTA = 0x04;           // (= 00000100) 8-bit transmit, transmitter NOT
                        // enabled, asynchronous, high speed mode
RCSTA = 0x90;           // (= 10010000) 8-bit receiver, receiver enabled,
                        // continuous receive, serial port enabled
/* configure the interrupts */
INTCON = 0;             // clear interrupt register completely
INTCONbits.INT0IE = 0 ;
RCONbits.IPEN = 1 ;     // Enable priority levels on interrupts
/*portb interrupts end*/
TRISB = 0x3E;
INTCON2bits.RBPU = 0 ;
PORTB = 0 ;
PIE1bits.TXIE = 1;      // enable USART transmit interrupt
PIE1bits.RCIE = 1;      // enable USART receive interrupt
PIR1 = 0;               // clear all peripheral flags
INTCONbits.PEIE = 1;    // enable peripheral interrupts
INTCONbits.GIE = 1;     // globally enable interrupts
share|improve this question
Have you scoped the Tx line of the PIC to confirm there is any activity on it? Can you post your full code also? (including config bits, the interrupt routine, etc) –  Oli Glaser Jan 14 '13 at 19:55
add comment
discard
