Tell me more ×
Without buying an expensive calibration tool, how can I accurately calibrate my multimeters?
share|improve this question
Why do you need to calibrate? If you need to calibrate in order to prove to someone else that your meter is up to snuff, you might want to contact a calibration service - they have all that expensive equipment, so you don't have to. – Michael Kohne Oct 23 '10 at 17:40
I'm only a hobbyist with low budget. The goal of the calibration is that my 3 different multimeters do not show three very different values for the same measured object :) I've already made same lenght measurement cables for them from low resistance silicone wire, next step is to calibrate them to a good reference. – csadam Oct 23 '10 at 20:06
How far apart do they read right now on what value resistor? – Nick T Oct 25 '10 at 3:59
up vote 11 down vote accepted
You can buy a few 0.1% resistors to calculate resistance ranges cheaply.
Voltage is tricker - if you have access to several meters you can 'calibrate by consensus', as it is improbable that they will all go out in the same direction.
Another option is buy a precision voltage reference IC - e.g. AD581 is 10V with 0.1% accuracy.
Current can also be done using voltage across a known, accurate resistance.
share|improve this answer
Bring them to your university or employer, and see if you can get them to calibrate them for you the next time they do their calibration run.
No, I'm serious. I expect that most schools and employers will be happy to see that their students and employees are developing their skills outside of the school/work environment, and when you've got a production line set up for a hundred meters already, the addition of one (or a few) more meters isn't that big of a deal.
discard
