Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I have a range hood that has an expensive (IMO) transformer that has went bad. Here is the link to the transformer that went bad: http://www.repairclinic.com/buy/1/14238-transformer-oem-5304464262.html
Does anyone have a suggestion on how I could replace this transformer with a cheaper alternative? Would something I have around the house have a transformer in it that would work? Could I buy something broken on craigslist and take it out? Would Lowe's or Home Depot carrry something that would work?
As you can see it is a 120v to 12v transformer. And something went wrong? enter image description here
share|improve this question
closed as off topic by Leon Heller, Brian Carlton, Nick Alexeev, placeholder, Anindo Ghosh Jan 18 '13 at 4:50
Questions on Electrical Engineering Stack Exchange are expected to relate to electronics design within the scope defined by the community. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about reopening questions here.If this question can be reworded to fit the rules in the help center, please edit the question.
Before you replace the transformer, figure out why the device on the heatsink made that burn mark on the inside of the case. The transformer failure might be a secondary effect. (No pun intended :-) – Dave Tweed Jan 17 '13 at 20:42
I think OP is referring to replacing the entire device as 'transformer' in contrast to the brown and ferrite core transformer that I initially thought was meant. The whole device is called 'electronic transformer'. Would be good if OP clarified what he means by 'transformer' in his question and at the same time indicate specifications other than 12V and 1120V – jippie Jan 17 '13 at 21:16
All the specs are listed on the link. That is why I didn't list them all out. – Kyle Rogers Jan 17 '13 at 21:48
@Kyle Rogers So we're supposed to click on the link, spend time looking on the page for specifications, figure out that there aren't any and then read what the sticker on the image of the part says because you couldn't be bothered to type it out? That seems a bit rude to me. – AndrejaKo Jan 17 '13 at 22:17
@KyleRogers Can you describe the diagnostic method by which the transformer was determined to be bad? The transformer is just that brown coil surrounded by the black iron square. – Kaz Jan 18 '13 at 1:07
up vote 1 down vote accepted
Any time you replace a safety-critical component, the onus is on you to ensure that you're not violating any regulations or local laws.
Based on your link, the transformer that failed has a big backwards UR mark on it, which means its an Underwriters Laboratories recognized component. Most likely the safety certification of the entire hood relies on this one piece of equipment.
If you improvise something, or try to fix it yourself, or replace it with a 'cheaper' alternative, beware: if something goes wrong you're responsible and most likely wouldn't get any insurance money for it either. My advice: replace it with the same part or get a new hood.
For what it's worth, the features listed on the label: thermal protection, short circuit protection and your picture make it clear that it's more than just an AC transformer in there. I see a bridge rectifier, some capacitors, possibly a sleeved inductor along with the transformer. There's probably some housekeeping going on in there along with the step-down functionality.
share|improve this answer
Thank you for taking the time to answer. Perhaps you are correct and I shouldn't gamble with safety. – Kyle Rogers Jan 17 '13 at 23:20
