Tell me more ×
I was looking at a this CUI power jack connector and I noticed that it has a switch which is NC, and I think goes open when a connector is plugged in (pin 2/3).
There's no clear distinction I can make out between which pin (pin 2 or 3) which is actually electrically hooked up to the outer housing (in my case ground since my adapter is center positive).
Which pin should I connect my ground to? If I don't need to detect if the jack is plugged in, can I just short out the two pins and not worry about the issue?
share|improve this question
1 Answer
up vote 1 down vote accepted
The pin numbers of the connector are identified in the data sheet that you linked, both on the small schematic and on the footprint/hole diagram.
Here is an annotation of the connector schematic.
As drawn the connector barrel pushes down on the contact and opens the point switch contact to pin 3.
share|improve this answer
I can't tell from the schematic which is which. – helloworld922 Jan 17 at 21:26
The pin numbers of the connector are labeled in the drawing on nearly every view. In the schematic the connector view for pin 2 shows the actual connection that contacts the outside barrel contact. I'll add a picture to my answer. – Michael Karas Jan 18 at 0:29
discard
