Tell me more ×
This is the contact used on the Xbox 360 battery pack. Is it a custom part that was made for Microsoft or is it an of the shelf part? If it is a custom part is there anyway I can replicate it short of sending it off to China?
share|improve this question
@LeonHeller sure, but why can't we leave the question as an identification question. Finding connectors so that hobbyiest can use surplus/refurb batteries for commodity products seems very much on-topic. – Andrew Kohlsmith Jan 20 at 22:30
It is not for repairs. Its for a modified controller power supply I am building – Jonny Flowers Jan 20 at 22:38
...then it's even more on topic ;-) – DrFriedParts Jan 20 at 23:18
are you building the controller or battery? Which side of the connector are you interested in? – Chetan Bhargava Jan 22 at 8:25
The battery side. So I need the part pictured – Jonny Flowers Jan 22 at 12:39
show 4 more comments
1 Answer
Well, you can find the male connector apparently. http://uk.farnell.com/jsp/search/browse.jsp?N=2031+203470&Ntk=gensearch&Ntt=battery+connector&Ntx=mode+matchallpartial
But this connector can easily be improvised. If you have a hot glue gun you may cast the connector using bits of metal. I've made a few connectors out of silicon (hot glue), and they work quite good. Be creative :D
share|improve this answer
On your link I only see connectors with 2, 3, 4 or 5 connections. The image shows 6 connections. Can you add a direct link to the product you mean? – Camil Staps Feb 12 at 14:58
Here is a link to a 6 contacts connector. The problem is that is a male and you need a female connector, but as I said you should be able to improvise one that would work. – user1410908 Feb 13 at 0:02
Hmm .. it seems they also have the female connector here. Beware that you have to pay extra 15$ for delivery, if you're outside US. Also, the picture is misleading, the connector has 6 contacts. Ask for assistance from Farnell. – user1410908 Feb 13 at 0:12
Only thing left to do is check the dimensions match the ones on the controller. The other solution would be to have a thicker PCB sit on top and act as the part – Jonny Flowers Mar 12 at 10:59
discard
