For my power system, let us suppose it has the following dynamic model: \$\ x ' = f(x,u)\$.
This dynamic model consists of four first order differential equations (see below).
Then, I linearized my system using Newton-Raphson method. My new linear system will be:
\$\ \Delta x ' = A \Delta x + B u +\$ disturbance
Where:
\$\ x \$ is the state vector that that contains 4 first order differential equations: (the power angle δ , the angular speed of the rotor ω, the generated voltage in the quadrature axis of the generator eq', and the field voltage of the generator in the direct axis \$\ E_d\$ ). a.k.a.: \$\ \Delta x = [\Delta \delta, \Delta \omega. \Delta e_q' , \Delta E_d ] ^T \$
\$\ u \$ is the control part. Let us make it zero for now
Let us assume that the disturbance in the power input of the generator is just 30% (0.3 pu) for only 1 second.
- "A" is a 4 x 4 matrix. Let us say:
$$ A= \begin{bmatrix}1 & 2 & 3 &4\\5 & 6 &7 &8 \\9 & 1 & 2 & 3\\4 & 5 & 6 & 7 \end{bmatrix} $$
The question is:
How can I model the system shown above using MATLAB? I want to plot the four state variables, but I don't know where to begin
Is there any specific code that will help me to simulate this system.
