I am trying to use a 27mhz RC car controller to send to an RC Car AM receiver and use that output (short 1-1.5ms pulse of a few mA) to trigger a 5V relay, with the signal stabilised via a retriggerable monostable-multivibrator I guess?
I thought this would be easiest and I have the junk bits lying around unused.
I have a few questions:
I am impatient so I replaced the 27mHz crystal in the sender with a 29.something because I had a matching one for the receiver. Given that it was a closed controller, is the sender circuitry likely tuned to ONLY the 27mHz crystal? I can solder the other back in when the new one arrives
The servo is a feedback circuit, but it is also self contained and does not send information back out. Will the Receiver signal output system likely work the same with the signal going to a transistor or mono-multivibrator and the power looping through a 5V relay coil? (instead of the servo setup) For instance will the sudden pull or jitter of the coil on the power supply mess with the signal?
Is there any easier way to do this? what if i put the coil inline with a mini servo +supply and it just picked it up like a load when the servo was "on"
(For reference, I just need to remotely trigger a solenoid/12Vbattery/relay hidden in Stage-props and for cheap. It is a heavy painting so I don't consider the servo an option)
