Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
As you can see here to calculators I found show huge difference or didn't I set it up correctly? I didn't found hints on possible validity limits. Can someone say if one of those given out results is correct? I mean a mismatch of 18 ohm is a no go... Both freeware, is there a commercial software with higher quality?
Edit: Added image with changed material, no significant change, as to my knowledge only the dielectric constant is important, which was set to same value in first 2 pictures. Am I missing something? enter image description here
share|improve this question
They are set to different materials, which probably affects the results. – Brian Drummond Feb 20 '13 at 22:47
As Brian said, make sure all the relevant specs are matched. Otherwise I can tell you that I've used TXLINE and it's very good. I've simulated and created physical boards and the numbers it gives are good. – Gustavo Litovsky Feb 20 '13 at 23:34
@BrianDrummond I changed the material, but in TXLine it seems it is only important what you edit in the dielectric constant field, the "material" tab just saves this numbers for a few materials – James Last Feb 20 '13 at 23:48
@BrianDrummond I dont know why ur comment gets more upvotes, I changed the material and it didnt improve, what am I missing? Can you explain, thanks! – James Last Feb 21 '13 at 12:50
Keep in mind this : electronics.stackexchange.com/questions/48867/… – Blup1980 Feb 21 '13 at 15:04
discard
