I'm building out a circuit with an ATmega 1281 MCU, some switches for input and a Nokia 5110 LCD (SPI interface) for display. I can load code on it just fine with my USBtinyISP programmer. With the programmer connected, the code runs great. It sits there and will chug away for hours. When I remove the programmer and reset the MCU, things either freeze up or the display gets really hinky and displays garbage.
Both the LCD and the ICSP are SPI interfaces. In attempts to get it run without the ISP connected, I've tried pulling both up and down with a 10K resistor on MISO, MOSI, SCK and RST. Nothing makes a difference.
Has anyone else ever seen this happen? What did you do to fix it?
(edit: image added to question)
