Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
So let's say I have a perfectly symmetrical Voltage transfer function curve for my CMOS inverter. The curve looks like this:
The question is, how would this curve change if the size of the NMOS transistor was reduced.
My answer: The curve would still be symmetric but would start shifting right.
But I just know that from my textbook, I don't understand WHY the curve would shift right.
So why exactly will it maintain symmetry and shift right?
share|improve this question
up vote 2 down vote accepted
The voltage shifts because additional over drive voltage is required to generate additional \$ I_{ds} \$ to match the \$ I_{ds} \$ of the PMOS. This arises because of the reduction of W reduces the \$g_m\$ of the NMOS transistor.
The curve will have it's roughly sigmoid shape, which is dictated by how the transistors transition from triode to full active, but they will not be perfectly symmetrical. \$V_{th} \$ , \$g_m\$ are very unlikely to be perfectly matched.
share|improve this answer
What would happen if VDD were less than the sum of the threshold voltages for the NMOS and PMOS transistors? My instinct would be that the inverter would show some vague hysteresis behavior, but a mushy signal passed through multiple inverters would remain mushy (unlike Schmidt trigger inverters which add hysteresis and give clean outputs). I could imagine that metastability would be a bigger problem at low voltages, requiring something more than a double synchronizer, but I don't really know. – supercat Nov 25 '13 at 18:51
protected by W5VO Feb 27 '13 at 8:27
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
