In a recent question on which PIC to use, one answer mentioned that a particular PIC had the feature that of debug hardware being built in, so that a special debug header was not needed. What is a debug header?
MPLAB ICD 3 In-Circuit Debugger
I think it's the same as an ICD header. Because on some low pin count chips the extra wires needed for debugging (two of them) can be significant compared to the total pin count of the chip, a bigger chip with more or less the same CPU core is produced for debugging alone. For example here is a PIC header for a PIC16F648A.
It's bigger than the actual chip and has extra pins for debugging support. Note the -ICD suffix on the part number. |
