Tell me more ×
I was looking into servos and I need some help choosing the proper one. I need a servo that has complete 180 degree motion but it's going to get hit by dogs a lot so it needs to hold it's position against a good deal of force. My biggest problem with this however is the fact that it needs to be tiny. I was thinking I might have to go with a locking gear system what do you recommend.
I am attempting to make self adjusting weave poles like these: self adjusting weave poles
The problem is dogs will be hitting them constantly and there is very little room for these servos. Especially with the fact that they will have to be operated using rechargeable batteries. In order to ensure that they are properly adjustable, they need to hold shape. Also I am designing a GUI that will allow them to be remote controlled so they can be set to different angles depending on the dogs skill level. Anyone have some ideas?
share|improve this question
migrated from diy.stackexchange.com Mar 3 at 16:22
I would approach this as a mechanical problem, not a servo-selection problem. Design a mechanism which can take a hit and keep the servo isolated, then you only need a normally rated servo (one that can move the object, rather than being strong enough to cut a dog in half).
I would look at adding some spring, rubber, a cush-drive, overload or slip clutch (or dog clutch, ha ha!), or just slack in the mechanism to allow the movement/impact.
Personally I'd look closely at other actuation methods, for example small pneumatic cylinders are easily actuated with solenoid valves and a £5 12v car tyre inflator can provide enough air, and being pneumatic they will take having their pistons moved by force and return naturally to where they're set.
share|improve this answer
I will look into this soon I am busy right now but thanks for the emotion in the response. To many of the responses I see on here might as well be a bot. – Griffin Mar 4 at 15:22
+1 for an intermediate spring. I'd +2 for pneumatics if I could, strikes me as a way better solution here than servos. – mac Mar 4 at 16:44
Alternative / a way of building in slack is to use the servo to pull a piece of string to move the part, then reverse to allow some slack. If you make it so that it has to rotate several turns to take up the slack & pull the other way, once it's moved it is sat in the middle of a piece of slack string, with enough slack that the part can move full distance without making the string go tight. – John U Mar 4 at 16:57
For things like this at work we often do pneumatics for the reasons discussed above, very good idea. – Kortuk Mar 5 at 19:34
Well, this is going to be tricky, and probably expensive. Your main problem is a dire lack of space. I assume you want to get the servos inside that central pole on the ground. But why do you need to confine yourself to the exact size and shape of the poles you have? Would it be so terrible if the bottom pole was double the width? What if it wasn't a pole at all, but a box, much wider than the pole, but the same height. That would give you much more room to fit your solution, and allow you to use much less expensive motors and gearboxes.
The first thing you'll need to do to spec the mechanical components you need is to do some calculations to determine the amount of mechanical load they must endure. How much torque will be generated at the gearbox of the servo by a dog running into it at full speed? Let's do a rough calculation, and assume a dog is just sitting on a horizontal pole.
Torque = force x distance
= weight of dog x length of pole
= 300N x 1m
= 300Nm
That's a lot of torque. Here's a typical servo motor which can produce 300Nm torque:
300Nm servo
This is a beast of a motor. It'll weigh a hell of a lot, cost a lot and consume a lot of energy.
What you may need to do is separate the ability to move from the ability to survive an impact. Make a brake, which disengages when you want to move the poles, and re-engages when you want to hold them still. This way, you can use a much lower torque servo.
That's what I ment with the gears. I can't have a box on either side because it would really mess up the dogs. – Griffin Mar 3 at 22:29
@Griffin - Try to work out what's the largest box you could have without messing up the dogs. – Rocketmagnet Mar 3 at 22:32
discard
