Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Any idea how I would go about designing a 3 bit synchronous counter in regards to having the following states
111->001->110->101->100->000->010->111
I drew up a present state and next state table etc... not really sure where to go from here, I have designed in logism a start schematic with a CLK, CLR and PRE, with 3 D type Flip flops as these are the ones I am required to use, but I am unsure where to go from here.
share|improve this question
up vote 0 down vote accepted
The key thing is to treat each bit individually.
For example, for the low-order bit, lets call it next_state[0].
state     | next_state[0]
   000    | 0
   001    | 0
   010    | 1
   011    | X
   100    | 0
   101    | 0
   110    | 0
   111    | 1
So you can write
next_state[0] = state[0] & state[1] & state[2] | ~state[0] & state[1] & ~state[2]
If you are building this with discrete logic you could simplify this to
next_state[0] = state[1] & (state[0] & state[2] | ~state[0] & ~state[2])
And you have an equation you can use to drive the flip-flop that will generate the next condition for the low-bit of the state variable.
Finding the equations for the other two state bits works the same way.
share|improve this answer
i must be missing something, how do you know 010 = 1? i'm lost in regards to how you got that table – Sim Mar 16 '13 at 5:33
According to your question, when the current state is 010, the next state is 111, which means the low bit is 1. – The Photon Mar 16 '13 at 5:39
can i use a 3 k maps for each different state? – Sim Mar 16 '13 at 6:04
Yes Karnaugh is the way to go here. Or a small microcontroller. – jippie Mar 16 '13 at 8:55
@Sim, one k-map for each bit of next_state is enough. – The Photon Mar 16 '13 at 15:57
discard
