I need basic electronics books (diodes,transistors,current..etc) as I am just starting out with electronics and want to have something to read over the holiday.
Any suggestions of good beginners' books?
I need basic electronics books (diodes,transistors,current..etc) as I am just starting out with electronics and want to have something to read over the holiday. Any suggestions of good beginners' books? |
The Art of Electronics:Paul Horowitz and Winfield Hill Often described as the Bible of Electronics. Its fair to say that if you buy this one, you wont need another for a while! Contents:
It takes a bit of a commitment to read it all, but it is the sort of book that you can pick from. Not to heavy on the maths. |
While this isn't a book, the online All About Circuits site is fantastic. The examples are simple and easy to learn from. I use that in conjunction with some of the other books I have (which all have some pluses/minuses):
I don't recommend Getting Started in Electronics by Forrest M. Mims III. I tried to use this to learn electronics as a kid and I think it mislead me more than it taught. I remember being frustrated by my inability to make simple circuits work, and I think this book's simplistic descriptions are partially to blame. Some examples:
I struggled with these descriptions for years. Only when I got to college did I finally start to learn this stuff, rather than poke in the dark and hope that things worked. I think William Beaty's Electricity Misconceptions pages are much better at explaining electricity in an intuitive, but accurate way, and helped "unteach" all the incorrect things I learned from other books. Another book I don't recommend is Sedra & Smith's Microelectronic Circuits. Their teaching method for transistors is very unintuitive and impractical, for instance. If you want to memorize a bunch of equations without actually learning anything you can use to build circuits, this is the book for you. Art of Electronics does a much better job of teaching transistor circuits. It's good and practical. |
I really enjoyed Practical Electronics For Inventors by Paul Sherz. It's easy to read and fun without being simplistic and glossing over important details. As the title suggests it's geared toward hands on practical electronics rather than someone studying for an EE degree. For example there's a page comparing the types of capacitors available and how to recognize each. It has a good amount of detail without getting dry and textbookish. There's not very much detail on modern microcontrollers in this book, but don't let that stop you, just grab another book dedicated to that topic if you're interested. You'll need to learn what's in this book to get the most out of using microcontrollers anyway. |
So to sum up the /. article and add a few cents. Highest recommended were the following: Art of Electronics, Horowitz get an Arduino and play/walk through the plethora of howtos Practical Electronics for Inventors: Paul Scherz Getting Started in Electronics: Forrest M. Mims III I was surprised to not see "Black Art of Game Console Design", "Physical Computing" or "Making things Talk". Course my filters may have knocked them off, or folks might consider them to be a bit too practical. |
First, "Make: Electronics" then "The Art of Electronics" (2nd ed.) by Horowitz and Hill. |
If you're just starting out I would recommend both Getting Started in Electronics and Make: Electronics: Learning Through Discovery The Getting Started in Electronics book as become a standard in the electronics world since it's initial release in the 1980's. It's easy to read and follow and has taught electronics to a lot of folks. Make: Electronics is a little more hands on and will introduce you to the theories as you are building real circuits. It's a fun book but be warned to get all the parts you need for the book you will end up spending about two hundred dollars. Don't let that scare you though because if you are wanting to learn electronics you're going to have to invest money at somewhat to get the basic stuff this book is asking you to get at some point anyway. Doing it this way at least helps you get a list of things that you will need together. It's not as proved as the Getting Started in Electronics book but I think it will be another standard for anyone getting started in a few years. The Art of Electronics that was mentioned by another person is a good book but it may be to technical for folks just starting out. There is my 2 cents. Good luck with your learning and have fun, |
Check out this slashdot question on the almost exact same topic. Make sure to set the comments threshold to see only comments rated +5, and you'll see all the most popular suggestions. |
tronixstuff recommended "The Art of Electronics". I think the associated student manual would also be helpful. It has 23 labs, 20 worked examples, extra notes and associated reading assignments out of the main text. Here's an informal YouTube review of the student manual: http://www.youtube.com/watch?v=yCk56XPKw9g I know you're not looking to read a whole lot, but I figure it can't hurt to include some links that you may find useful. Lectures:
Books:
Articles & Tutorials:
Applets & Simulations:
I really liked "Make things talk". it doesn't explain to much theory, but helps you to get your first projects started. |
If you want a very affordable and welcoming book rather than a college textbook, I highly suggest All New Electronics Self-Teaching Guide. It's a gentle introduction to electronics that has you work through examples so that you grasp the concepts. It will get you through the basics: DC, diodes, BJTs, FETs, AC, oscillators, resonant networks, transformers, etc. I used the original version years ago and it helped start me on the path to where I could work with the more comprehensive (and technical) textbooks like Sedra & Smith. |
A good beginner book that covers transistors (and plenty of other stuff) is the excellent "Art of Electronics", which you will see recommended everywhere. Old but still very useful. Specifically transistor orientated, the best book I have seen is: Principles of Transistor Circuits - a very in depth book, now in it's ninth edition. If you are new to all this I would recommend starting with something less "in depth" such as Practical Electronics Handbook, Practical Electronics for Inventors, or the above mentioned AOE, and then proceed to this. |
Books Beginner's Guide To Reading Schematics - I find myself returning to this over and over again to figure out circuits on various devices that I tend to disassemble. Embedded Software Primer - A good intro for beginners Practical Electronics for Inventors - Awaiting shipment - seen mostly good reviews on this. There are some typos that are supposed to plague this edition - however if you aren't a greenhorn, I guess it would not pose a big problem. Websites Robotics India - A good resource for beginners and pro's alike Hack-a-day - no intro needed, I guess. Lets make Robots - another great robotics site. Rgds, Sushrut. |
I'd suggest following the course at edX "MITx: 6.002x Circuits and Electronics". It' s not just a book, it is a really serious course and you are forced to do homework and labs in order to get a certificate, so there is higher motivation then reading a book |
I find the book Electronic Devices and Circuit Theory by Robert L. Boylestad and Louis Nashelsky, great. Best description of BJT hybrid param equivalent model, diodes, good description of JFets, Darlington and feedback circuits. It will surely encourage anyone take VLSI/Analog as a career. |
Also I subscribe to the RSS feed for this weird site called Chiphacker. Not sure what that's all about... |
http://www.graffe.com/forums/forum.php - Lots of things of general interest, gaming discussion, political and news. |
One of my favorite electronics books is "Practical Electronics for Inventors". Ignore the title, it has nothing to do with inventions and patents. It starts out with a basic intro to electronics, various electronics components, semiconductors, optoelectronics, ICs and op-amps, filters, oscillators and timers, voltage regulators and power supplies, audio electronics, digital electronics, motors, and ends up with constructing circuits, multimeters, and oscilloscopes. |
Getting Started in Electronics [Forrest M. Mims III] is a very simple book that gives a gentle introduction to a broad range of electrical topics. It is definitely worth a read for anyone starting with electronics. |
You can't go wrong with the other suggestions, but at least consider the ARRL handbook? If you're just starting out you need a wide ranging survey... if your brain is hurting from transistor equations, read about lightning protection for awhile. So you've got the theoretical knowledge of which amplifier class has lower distortion, but until you understand why you want that... 73 de N9NFB |
In the German speaking part of the world Tietze, Schenk: Halbleiterschaltungtechnik. is very famous. There is also a English translation: |
I started with Electronic Devices and circuit theory by Robert Boylestad. It started with the very basics and was a great book to begin with. Also Microelectronics Circuit Analysis and Design by Donald Neamen is a good resource for a beginner. |
I am supprised to see that noone has mentioned Sedra & Smith Microelectronic Circuits. It starts from very basic consepts in the first few chapers, but then covers pretty much everything. The book contains a lot of circuit analysis and design examples. I got it for the sencond year electronics class and ended up returning to it over and over again for different classes as well as for work related stuff. |
I started of with "Electronic Devices and Circuit theory" by Boylestad and Nashelski and found it quite impressive with its perfect blend of concepts and up-to-date technology, so I would suggest you the same. |
My coursebook was Basic Electronics by Bernard Grob. I think it's an excellent reference and covers electronics basics very thoroughly. (I had 6th edition in my class; it is currently at 11th edition.) |
CODE: The Hidden Language of Hardware and Software This is a great book that starts at the very beginning of understanding electronics. I am a professional EE and I really wish I had read this book before even starting my EE courses in college. A great read for any newbie or advanced engineer. |
I'm not sure what level you want to be learning at, whether seriously or just for fun, but if you want to get a taste of electronics, consider the Evil Genius Series of books. They have fun projects that you can do at home with stuff you can find at some of your local stores or even online. They explain how it works, just for you to get the basics of it, which I think would be great for you. If you start to develop a taste for electronics and want to really know more, then start going into the more technical and "mathy" books that really explain how you can move electrons around. |
Check this book: This book explains electronics from a different perspective. For more information on this book visit the author's homepage. I would also suggest The Art of Electronics, by Paul Horowitz and Winfield Hill as others do. |
This question is protected to prevent "thanks!", "me too!", or spam answers by new users. To answer it, you must have earned at least 10 reputation on this site.
