What was your worst electronics workbench accident involving equipment, voltage, soldering irons, chemicals, or whatever else, and what changes have you made to prevent that type of accident from happening again?
feedback
locked by Kortuk♦ Feb 17 at 2:37
This question exists because it has historical significance, but it is not considered a good, on-topic question for this site, so please do not use it as evidence that you can ask similar questions here. This question and its answers are frozen and cannot be changed. More info: FAQ.
Here are some precautions I take... they might be a little excessive but I'd rather play it safe. Soldering:
PCB Manufacture:
feedback
Only a switch that cut the power to everything, so that I don't forget something turned on (like the soldering iron...)
feedback
Never, EVER use a chair with open armrests (non-closed loops) at a workbench with soldering irons. It's just a matter of time before a hot soldering iron is grabbed by its cord (courtesy of your chair) and introduced to your groin area. Yes, I'm still fully functional. I did burn a pair of pants, though. | ||||
feedback
Regularly clean/organize my bench. Fewer knives hiding, waiting to stab me. | ||||
feedback
How about a soldering iron with automatic turnoff? Don't want to leave that thing on all the time... | ||||
feedback
I admit that I don't have much experience, but the thing which isn't mentioned here and helped me the most was thinking steps through before doing anything. I've burned myself several times and I noticed that each time that happens, it's because I want to just do something without thinking how I'm going to do it. So I have a circuit board and want to desolder something. No problem, right? I'll just desolder it and that's it. Well, that kind of thinking got me burned. Instead I found it better to separate "complex" operation into simple steps and plan on what I'm going to do if it doesn't work correctly and stop if I get into area I did think of. So for my desoldering example I'll first examine the board and decide where I'm going to apply the soldering iron, if I'm going to use vacuum pump or desoldering braid, what am I going to do if solder melts and part is still stuck, what am I going to do braid sticks to the part and so on. The thinking part does take a couple of seconds, but I think it's better to wait a few seconds than to burn yourself. | ||||
feedback
Many, many years ago when I was around 5-10 I burnt my fingers a lot on soldering irons, but hey, kids heal fast, so no biggie, I still have one faint scar from that time. Many years ago when I lived at home and had a 6 year old little brother, I left my soldering iron on when I left my room, my brother knocked the iron on the floor and picked it up, using the wrong end. My parents were not impressed. ... so, yeah, I second the big red rocker switch. More recently I was digging around a digital camera and I accidentally grabbed the flash capacitor, it burnt a black mark in my finger while delivering the worst shock I've had since I cut a live 230 V line. Recovering from the shock took a couple of minutes of cursing. I then proceeded to take my multimeter to measure the voltage on the capacitor, but I fat-fingered it and the probe slipped to short out the cap, enough energy was released to leave a blackened area in my eyes for 10 minutes afterwards and the PCB around the HV traces basically exploded. ... but other than that I've been pretty safe, so there hasn't been many improvements, other than to add "the big red rocker switch" to power down everything on my workbench at once. | ||||
feedback
Common accident: burnt fingers and/or wires. Rinse and repeat. | |||||||||
feedback
The jumbo version of the big red rocker is to get a contactor installed in your lab Then there can be an off switch (Big E-STOP button) at the door. So somebody trying to save you doesn't get electrocuted either. The training from my aluminum smelter days won't go away. The real reason is to get a second off switch repeater put somewhere you actually live. then you can say "hey I left the lab on!" and turn it off without havng to go too far ;-) Of course, if your workbench is only little, you can probably hook up an E-Stop loop pretty easily with a consumer grade power control switch. Consider an E-Stop loop. The life it saves will probably be yours. | |||||
feedback
I used to regularly nock my bottle of beer off the bench to smash on the concrete floor, which made me sad. Now I keep a mangled roll of duct tape on a secondary bench so I don't spill. Pretty sure this qualifies me for a CSA:OH&S medal of honour or something, but I don't like to brag. | ||||
feedback
When I was around 15 I spent a lot of time soldering stuff on the floor, since my desk was far too small to fit everything. Working on the floor has its specifics, namely - you crawl around on all fours a lot. It was only a matter of time before I "stepped" onto the soldering iron with my hand, placing my entire weight on it. I spent the rest of the day holding various cold glass cans from the fridge, replacing them every 20 minutes. Improvements made since: get a properly sized desk. Now that I am paying for my own furniture, my hobby desk is 5 feet wide and is bordered on one side by another large desk and on the other side by a rack of shelves. Not that I don't run out of space occasionally, but at least I no longer solder on the floor... | ||||
feedback
Any good chemistry lab only has stools, rather than chairs. If you spill something and need to step away from it quickly (before it runs off the counter and into your lap), you don't want a chair with a back. | ||||
feedback
