GAL chips seem expensive to get started with, since programmers cost hundreds of dollars and even ISP cables aren't cheap.
Is there a cheaper way?
GAL chips seem expensive to get started with, since programmers cost hundreds of dollars and even ISP cables aren't cheap. Is there a cheaper way? |
I'm not even sure GALs are still around today. CPLDs and FPGAs are preferred I believe, though I'm no expert. You can dig up development kits from digilentinc.com. There's a CPLD kit for $18 and the USB JTAG programming cable is $50. Those parts are Digilent C-Mod and JTAG-USB Cable. I believe the software (at least starter software) is free. Good luck! |
Here is the schematic for a simple home-made PCB for experimenting with Xilinx XC9536 CPLDs. It has a connector for a Xilinx programming cable, a socket for a crystal oscillator and an LED, as well as a small prototyping area. The artwork file is available. |
Standard GALs need funky voltages and waveforms for programming. Lattice do some 'ispGAL' products which added an IS interface, but unless you want to stick to DILs and/or 5V, low-end CPLDs are more capable and easier to program. |
A simple GAL programmer: http://elm-chan.org/works/pgal/report_e.html And if you want to know how to program: http://www.rexfisher.com/Downloads/CUPL%20Tutorial.htm |
