Tell me more ×
I know that getting a perfect tuning network for an antenna and transceiver requires some rather expensive equipment plus human knowledge to operate the equipment. I have never done any antenna tuning, but I would like to know if there is any way a DIYer can perform at least a semi-decently good match.
Is there any way I can use an oscope to do this? Is there any difference between tuning a PCB antenna versus a wire antenna?
share|improve this question
what frequency range? – Mark Nov 7 '10 at 18:22
I am looking at 2.4GHz, but would consider lower (434 or 900) if it was the only way to tune myself. – Kellenjb Nov 7 '10 at 18:25
up vote 3 down vote accepted
Here's the "Dropout's guide to antenna design"
http://colinkarpfinger.com/blog/2010/the-dropouts-guide-to-antenna-design/
share|improve this answer
I like that they call it an NA. – Kortuk Nov 8 '10 at 15:23
I worked with a guy whom could look at the smith chart every time and put the components on that would tune to 50 ohm. He had been doing it for years he could tell how the parts would react. – Kortuk Nov 8 '10 at 15:24
Very helpful. Still requires expensive equipment though. – Kellenjb Nov 8 '10 at 17:41
You should get a second opinion on this, but if you don't need a super wide-band analyzer, check out Wi-Spy. The $99 variety claims to let you "see interference", and that interference would be whatever you are firing up at 2.4GHz. It's a simple spectrum analyzer, but might be enough for what you are doing.
spectrum analyzers are not what is needed for tuning, you want a VNA. – Kortuk Nov 8 '10 at 0:54
Could make use of the RSSI (Received Signal Strength Indicator) on many RF transcievers to give you a rough indication.
Rough is the operative word. – Kortuk Nov 8 '10 at 0:54
discard
