How do I tell which wire is which if I have a copper wire, red and green coded wire? Is the unshielded copper wire ground?
Tell me more
Electrical Engineering Stack Exchange is a question and answer site for
electronics and electrical engineering professionals, students, and enthusiasts. It's 100% free, no registration required.
Red is for Right. Blue (or green) is for Left. Copper is for ground (I remember this with the mnemonic Red Right bLue Left Copper Common). All 3 are coated in a lacquer you need to burn or scrape off before you solder. With standard headphone plugs, with the plug facing away from you, the right pin is right, the center pin is ground, and the left pin is left.
It's probably the case, check resistances between the wires with a DVM to make sure. Listening to the noise made will tell you which is connected to right or left. |
