Tell me more ×
For a project we're thinking of generating electricity out of wet newspapers. Is that possible? How much current would it generate?
share|improve this question
Electrolysis (in title) is often used to split water into H2 and O2--distinct from generating electricity (in text). Which is your aim? – Nick T Nov 15 '10 at 14:41
Thanks. Changed the title. – Patrick Nov 16 '10 at 7:30
Why newspapers? – Connor Wolf Nov 16 '10 at 8:56
up vote 6 down vote accepted
You will need to soak your newspapers in a suitable electrolyte, water will not work. You could try lemon juice as a weak acid (vinegar could work). You will then need two dis-similar metals one for the Anode and the other for the Cathode. Let us say a piece of copper and a piece of zinc (galvanised steel will do). Place the two metals in contact with the sodden newspaper and measure the voltage between the plates. You should get around 0.85V. You will not get much current out of this cell as the internal resistance of the soggy newspaper will be quite high. It should light up an LED.
You could just get a lemon and stick the two metals through the skin into the fruit, dispensing with a messy pile of soggy newspaper.
share|improve this answer
It mostly depends on
  1. the chemicals the newspaper has been soaked in.
  2. The material of the electrodes placed in/on the newspaper.
I seem to remember a project a while back which used copper and zinc for +/-. Something about the different metal properties allowed electricity to flow. Do some searches with those keywords.
Thanks for all the answers. I will research further with these informations. – Patrick Nov 16 '10 at 9:47
The newspapers themselves won't generate any electricity as they don't react with anything. Batteries are formed by compounds with dissimilar electrode potentials, so you will require some sort of additional reactants (usually metals) that you could keep separate with newspaper. Copper/zinc as Brad mentions are fairly easy to obtain and cheap, though the possibilities are vast (magnesium, lithium, iron, tin, nickel, silver...)
The current any battery generates is based on the speed it can react components, which is governed by the geometry of the cell above all else. If you only know the materials (we don't here anyways), the best you can do is estimate the voltage.
Alternatively, you could use wet newspaper as a spacer for aluminum electrolytic capacitors. Roll up paper-foil-paper-foil, apply a reverse voltage to grow the aluminum oxide dielectric, and presto, capacitor.
Once upon a time you might have been able to get a weak voltage from soggy newspapers. The ink that was used had small amounts of various metals that would be conductors. The paper itself was bleached and certain amount would not get rinsed out.
Today the ink is soy based, it does not contain any metal. The paper has little if any chemicals left in it from processing. You could add metal as electrodes and add a electrolyte like acetic acid (citrus juice), but if you do that you don't need the newspaper.
There has been some attempts to use cellulose (paper) with carbon nano tubes suspended in ink for manufacturing batteries, but this is much more the wet newspapers.
Wow, thank you. I had the ink in mind, but didn't know it has been changed from metals to soy. I guess, this is not going to be the solution for our project then. – Patrick Nov 16 '10 at 15:14
discard
