Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
This is a two part question and pertains to power generation:
  • What prevents a larger plant (say nuclear) from turning an itsy-bitsy gas generator into an electric motor and drive current through it? (obnoxiously large diodes?)
  • How does the entire portfolio of power generators stay in sync/phase with the grid to produce one AC wave?
Edit: the second part seems to be already answered here. I'd appreciate a clear and convincing answer for the first part still.
share|improve this question
I'm sure I've seen this exact question here not long ago. – Kaz May 14 '13 at 20:18
@Kaz link it please. Best I found was: electronics.stackexchange.com/q/19531/4642 – MandoMando May 14 '13 at 20:23
Found it: possible duplicate of What keeps mains power at 60hz? – Kaz May 14 '13 at 20:26
@Kaz not quite the same. None-the-less, I edited the question for clarity. – MandoMando May 14 '13 at 20:31
So, suppose two generators are supplying a grid. One of the generators is slightly lazy and so it just spins along with the frequency: it avoids being driven, but does not put in any work. Then, demand on the grid rises. The other generator gets bogged down and slows down. The lazy one, lazy as it is, is still committed to maintaining the frequency. Since the grid frequency has slowed down slightly, that means the lazy one is now engaged: it is pushing the pace to help speed up the grid, thereby becoming engaged. It's much like when people combine forces to row a boat, or pull a load. – Kaz May 14 '13 at 22:27
up vote 10 down vote accepted
Short Answer: Synchronizers
Basically, feedback is used to keep the generator and grid in sync.
There are many ways to do this. A nice overview is here.
Virtually all modern power generation systems use some form of digital controller for the task. My grid-tied solar panel inverter has a PIC18F class microcontroller managing some solid-state relays (SSR) if I remember correctly.
Common Modern Power Station Design
Here is my summary of what I believe to be the most common basic approach to modern power generation plant design. Figure and text adapted from:
"Fundamentals and Advancements in Generator Synchronizing Systems," Michael J. Thompson, Schweitzer Engineering Laboratories, Inc. Dec. 9, 2010.
In the figure...
  • Returns are not shown
  • G1, G2 are the generators
  • Squares 1,2,3,4 are relays
  • Bus1, Bus2 are out-bound power busses (redundant)
  • MGPS units are GPS-synchronized clock sources for timing the generators
  • A25A is the measurement and control unit (contains a microprocessor)
How it works...
Modern microprocessor-based components and "digital" timing gear, like synchrophasors, have revolutionized the way generator synchronizing systems are designed.
For example...
  1. The "A25A" in the figure is a microprocessor-based automatic synchronizer with six isolated and independent single-phase voltage sensing inputs that eliminates the need to physically switch voltage signals.
  2. The 1,2,3,4 "digital" relays provide streaming synchrophasor data.
  3. Relay-to-Relay communication in the A25A allows it to be located close to the synchronizing breaker with control signals sent back to the devices which slow down (governor) or speed-up (exciter) the generator mechanism via fiber-optic links.
Timing and Control...
The ability to build systems for monitoring and control using low-cost, fiber-optic communications links has completely changed generator synchronizing systems.
The "digital" relays take direct synchronized measurements. Synchronized phasor measurements are measurements of the phase angle of power system quantities relative to a universal time reference.
Today, the precise time reference required to make this phase angle measurement is easily obtained from protective-relay-grade Global Positioning System (GPS) satellite clocks.
Synchrophasor technology allows voltage readings from various devices throughout the power station to be compared for angular difference. The data can be streamed at rates up to 60 messages per second with low latency.
Since phasor measurement unit (PMU) functionality in protective relays was first introduced in 2000, they have become nearly ubiquitous, and synchrophasor data are available nearly everywhere at no additional expense to the power plant owner.
A dedicated computer, running synchrophasor data concentrator (PDC) software, can receive streaming data from the various microprocessor-based relays applied for protection and control of the synchronizing breakers.
Just as the microprocessor-based automatic synchronizer can select the appropriate voltages for each synchronizing scenario from those wired to its six input terminals, the PDC can select the proper signals in its incoming data streams for the incoming and running voltages based upon operator selection of the generator and breaker to be synchronized.
No physical signal switching is required. And the synchrophasor voltage measurements from the breaker control relays are independent from the measurements of the automatic synchronizer, which makes the systems redundant.
Lag-Lead
@Kaz had provided a nice summary of directly slaved motors/generators in the comments (documented here for posterity ;-) ):
This is like asking, what keeps the slave rowers in a boat from just passively letting their oars drift with the water and not do any work? Well, there is a guy who beats a drum and so everyone has to pull at the same frequency, or get whipped. If the slaves get lazy, the boat will slow down, and soon, they will not be able to maintain that rowing frequency without exerting force on the water to speed up the boat again, or else letting their strokes be so obviously small (to match the slow speed relative to the water) that they all get a whipping from the guard.
In modern power plants, continuing our prior discussion, the approach is simple architecturally: each generator is slaved to a global time reference.
As explained above, the generators are phase locked to a global clock. They are each individually held responsible for their output being at a certain phase angle at a certain time.
If they are too fast, a device called a governor which is attached to the generator applies a braking force. If too slow, an attached exciter adds energy to speed up the generator.
As a side note, you can implement both functions in the same device in some architectures. For example, with a mechanical rotating mechanism, you can attach an electric motor to the axle and resist (govern) or assist (excite) the rotation by driving the attached motor in reverse or forward respectively.
Given that all generators are running in phase with the same time reference, sync is achieved.
Load Shedding
I can understand the sync, can you explain how 'it ensures that the generator is pushing current out rather than taking current in'?
This part is intuitive. Look at Ohm's Law or Kerckhoff's Laws...
If two voltage sources are in sync it means they produce the same voltage at the same time. If a perfect wire connects two voltage sources at the same voltage, zero current will flow in that wire.
If you connect a "large" generator and a "small" generator you are only describing a difference in maximum current at the same voltage generated.
As the smaller generator gets overloaded, it's voltage will fall. In rotating generators this results in a reduction in frequency (the rotor slows down) as the electrical loading applies a mechanical braking force through the electromagnet.
In either case, the synchronizers detect the overload condition as a loss of sync and disconnect the generator. This is called "load-shedding." As you can see, load-shedding only makes the problem worse for the remaining generators and the problem can cascade.
This is what happened during the NorthEast Blackout of 2003, although the event was caused by, among many things, a software glitch being too agressive with load shedding rather than actual overload.
share|improve this answer
great info for part 1 of the question. Can you update your answer for part 2? – MandoMando May 14 '13 at 20:11
@MandoMando - the same mechanism prevents this - it ensures that the generator is pushing current out rather than taking current in – Andy aka May 14 '13 at 20:22
@Andyaka I can understand the sync, can you explain how 'it ensures that the generator is pushing current out rather than taking current in'? Perhaps your own answer? – MandoMando May 14 '13 at 21:10
There's a nice example in the film Edison the Man, WB 1937 or so. He is about to power up the Brooklyn grid with two generators and one starts driving the other. Sparks etc. Instantly he gives an order to stop and connect the two governors together with a length of rod. IOW, feedback. And bingo, Brooklyn is lit. Note that this was DC so there was no phase feedback available in the electricity itself. – EJP May 15 '13 at 0:26
@DrFriedParts great. Now I understand, the bit about kirchhoff and ohm's law landed it. – MandoMando May 16 '13 at 15:59
There are no diodes, not in the normal AC system. I'm not sure you could build them that big.
As to the large plant versus small plant, the normal operation of the system keeps them in phase; if your generator is leading slightly, it will encounter more resistance and back EMF, which will tend to slow it down. If you're lagging slightly, there is less resistance and it's free to speed up.
When starting up a plant, it's very important to get it in phase (see the link by Dr FriedParts) before connecting it. Failure to do this will destroy something big and expensive.
Starting a plant up without a grid reference is a problem; see "Black Start", e.g. http://www.nationalgrid.com/NR/rdonlyres/99A34EB4-76F4-4042-AA12-35D6DD843FA7/3073/black_start.pdf
protected by W5VO May 15 '13 at 0:58
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site.
Would you like to answer one of these unanswered questions instead?
