Tell me more ×
Several other questions are posted about methods for flashing an LED, but one additional requirement I have is the ability to turn the circuit on or off with a micro controller (Netduino, 3.3v). This schematic is very close.
What changes would be necessary to achieve 38.5kHz? Also, how could I make an additional adjustment to start or stop the circuit via a pin on the Netduino?
share|improve this question
It sounds like you have an IR reciever that is tuned to 38.5kHz and you are wanting to transmit digital data to it? – Kellenjb Nov 19 '10 at 18:48
up vote 3 down vote accepted
You can tweak the frequency with the 5k potmeter. I think you can get a pretty good range with that. If it's not enough, you could probably change the other resistor to something or a little larger value so the frequency drops.
To make it possible to switch the LEDs on and off I would probably a transistor (or a MOSFET) after the two leds. You could then connect the base or gate to your netduino with a 1k resistor or so. It doesn't start/stop the circuit, but it does start/stop the LEDs which I think is the result you want to go after.
share|improve this answer
If you're using Netduino, maybe you can drop the 555 circuit and use software temporization. Here (http://www.netduino.com/projects/) we have two tutorials on how to blink the led and also how to turn it on and off using a button.
You will just need to attach the infrared led to an I/O port and map it in the software.
Thanks - I've tried to do this with the PWM pins but had trouble getting the frequency correct. – James Cadd Nov 19 '10 at 22:58
@JamesCadd, I have helped people do this, there was debug time in their software, but it was well worth saving the hardware in every case I have helped. – Kortuk Nov 20 '10 at 16:23
Since you have a microcontroller around for switching the signal on and off it makes sense to let it do the dirty work as well. I'm not acquainted with Netduino, but I see that it's an ARM7 running at 48MHz, which makes it more than powerful enough for this. Set a timer to a 13\$\mu\$s period, and let it toggle an I/O pin on each timeout. The signal's period is then 26\$\mu\$s, giving a frequency of 38.5kHz with only 0.1% error. Duty cycle will be 50%.
discard
