I am designing a circuit which may fail to start up. It has a power good output which is high when the supply is working. When the power good output goes low, the circuit has failed to start oscillating properly, and needs to be restarted. I thought about using a 555 timer but couldn't figure out how to make the output stay high when the input signal was low. Any ideas?
The circuit must do this because it fails to start under high current set points. It drives an LED. The idea is at higher currents the output folds back, but doesn't require an actual restart of the circuit to get it working again, and the fold-back mechanism makes the LED blink on and off.
Here's an image to show what I mean. Green shows the LED current. It has been set too high and the supply's overvoltage protection circuit kicks in to prevent more than 4.7V being applied across the LED (to prevent breakdown of the LED if in reverse.) The blue trace represents the power good output. During the oscillations the supply is outputting correctly, so it is high. It drops low after the oscillations stop. A short delay after it drops low, I need the supply to reset and try again - this would be accomplished by turning the supply controller IC on and off.
