Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I am taking a -8 volt signal and using a resistor divider to make it -3 volts by using a 16.5k ohm resistor as r1 and 10k as r2. I am feeding the -3v into a single supply opamp (+5 and gnd) in the inverting configuration with unity gain (using two 10k resistors) in order to obtain 3 volts. Will the resistor divider before the unity gain non-inverting opamp effect my unity gain?
Essentially i am taking a signal that goes from -8 to 0 and i want to turn this into 3v to 0 for input into a ADC.
share|improve this question
A schematic would really help this question. Click the 'edit' link, then there's a button in the editor toolbar, or press CTRL-M. – Phil Frost Jun 4 '13 at 20:05
What is your R3 doing there in 'series' with the inverting input? That's not the standard opamp inverting amplifier circuit! – Wouter van Ooijen Jun 4 '13 at 21:01
You do realize an LM324 will not achieve what you want in terms of output voltage capabilities? – Andy aka Jun 5 '13 at 7:16
if my single supply rail is 5v..and ground...i believe it will drive from 3 volts to zero at output. What spec are you looking at that says otherwise? – tsop Jun 5 '13 at 12:26
up vote 4 down vote accepted
Yes, the divider definitely will affect the gain calculation, because its equivalent source resistance (Thévenin resistance) of 6.23 kΩ is in series with one of your 10 kΩ gain-setting resistors. The overall gain will be -0.2325, rather than the -0.375 that you're looking for.
If you want an overall gain of -3/8, it would be simpler to forget about the voltage divider and just set up your opamp with 20 kΩ input and 7.5 kΩ feedback resistors.
Also, be sure to use an opamp whose common-mode input range includes ground.
share|improve this answer
i always hear that below unity gain is unstable for opamps..how can i be sure that that will be stable? Thanks – tsop Jun 4 '13 at 20:03
Actually, that was already a concern, even with your original circuit. – Dave Tweed Jun 4 '13 at 20:44
ya so i searched and looks like i just have to put a cap across the feedback resistor with a rolloff value above the freq of interest – tsop Jun 5 '13 at 12:30
discard
